PHP/Mapscript + Postgis
Jeff Portwine
jdport at VERITIME.COM
Wed May 11 09:41:51 EDT 2005
Do you have any error messages showing up in your web server error logs?
-Jeff
----- Original Message -----
From: "Philippe Gondek" <philippe.gondek at GMAIL.COM>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Wednesday, May 11, 2005 8:43 AM
Subject: [UMN_MAPSERVER-USERS] PHP/Mapscript + Postgis
I'm a beginner with mapscript...
I try to draw a map with php/mapscript with data comming from postgis.
I tried several ways, the problem is the construction of my layer...
I try like this
$map = ms_newMapObj($Nom_Mapfile);
$map->setextent($xmin,$ymin,$xmax,$ymax);
$map->web->set("imagepath",$mapserver_imagepath);
$map->web->set("imageurl",$mapserver_imageurl);
$map->set("width",$longueur_image_mapfile);
$map->set("height",$hauteur_image_mapfile);
// Ajout d'une couche
$layer = ms_newLayerObj($map);
with this mapfile
MAP
NAME MAMAPAMOI
EXTENT 0 0 1 1
SIZE 1 1
IMAGECOLOR 255 255 255
IMAGETYPE PNG
END
and like this
$map = ms_newMapObj("miam.map");
$layer = $map->getLayerByName(REGIONS);
MAP
NAME MAMAPAMOI
EXTENT 0 0 1 1
SIZE 1 1
IMAGETYPE PNG
LAYER
NAME REGIONS
TYPE POLYGON
CONNECTIONTYPE POSTGIS
CONNECTION "host=localhost port=5432 dbname=lemiam user=phil
password=1707loulou442"
DATA "the_geom from regions"
END
END
Each time, I have an
>>Internal Server Error
>>The server encountered an internal error or misconfiguration and was
unable to >>complete your request.
>>Please contact the server administrator, root at localhost and inform
them of the >>time the error occurred, and anything you might have
done that may have >>caused the error.
>>More information about this error may be available in the server error
>>log.
I don't understand why because I can completely read the script
http://localhost/phpinfo_mapscript.phtml
Do you already have a problem like this one???
