Projection and EXTENTS
Matthew Roberson
matt at MSILEADS.COM
Wed May 11 12:41:03 EDT 2005
Bart,
I'm not a projection expert either (obviously). I didn't convert my
shapefile to that projection, and it's quite possible that EPSG 26797
is not correct for my map. I will look into that. Thanks for your
help.
Matt
On May 10, 2005, at 2:11 AM, Bart van den Eijnden wrote:
> Hi,
> I am no projection expert but I can imagine your shapefile isn't in
> EPSG 26797 (or did convert your shapefile to that projection). The
> LAYER PROJECTION should have the source projection of the data in it,
> the MAP PROJECTION should contain the target projection you want.
> Best regards,
> Bart
> Syncera-ITSolutions
> Postbus 270
> 2600 AG DELFT
> tel.nr.: 015-7512436
> email: BEN at Syncera-ITSolutions.nl
>>>> Matthew Roberson <matt at MSILEADS.COM> 05/10/05 12:18am >>>
> I am trying to create a projection a map of the state of Missouri that
> was created by the US Census Bureau(zt29_d00.shp).
> I used ogrinfo to get the following information about the EXTENT:
> [imac-dev03:~/Documents] matthewr% ogrinfo -so zt29_d00.shp zt29_d00
> INFO: Open of `zt29_d00.shp'
> using driver `ESRI Shapefile' successful.
> Layer name: zt29_d00
> Geometry: Polygon
> Feature Count: 1341
> Extent: (-95.774704, 35.995683) - (-89.098843, 40.613640)
> Layer SRS WKT:
> (unknown)
> AREA: Real (20.5)
> PERIMETER: Real (20.5)
> ZT29_D00_: Integer (11.0)
> ZT29_D00_I: Integer (11.0)
> ZCTA: String (5.0)
> LSAD: String (2.0)
> LSAD_TRANS: String (50.0)
> Then, I used proj4 to find lat long values for the a Lambert Azimuthal
> Equal Area projection.
> [imac-dev03:~/Documents] matthewr% proj +proj=laea +ellps=clrk66 +R_A
> -95.774704 35.995683
> -7567149.62 5525023.18
> -89.098843 40.613640
> -6798293.00 5830370.88
> When I use these values with MapServer to make a map, nothing shows up.
> Am I missing something. Should I post this question in this list or
> in the MapServer User's group? Any help would be appreciated.
> Below is copy of my map file also,
> MAP
> NAME MO
> IMAGETYPE GIF
> SIZE 6000 6000
> IMAGECOLOR 240 240 240
> SHAPEPATH "/Library/WebServer/Documents/data"
> FONTSET "/Library/fonts/fonts.list"
> EXTENT -7567149.62 5525023.18 -6798293.00 5830370.88
> UNITS METERS
> WEB
> IMAGEPATH "/Library/WebServer/Documents/test/"
> IMAGEURL "/test/"
> END
> PROJECTION
> "init=epsg:26797"
> END
> LEGEND
> STATUS EMBED
> POSITION UR
> END
> SCALEBAR
> TRANSPARENT ON
> BACKGROUNDCOLOR 254 254 254
> STATUS EMBED
> POSITION LR
> STYLE 1
> END
> LAYER
> NAME "MO zip code boundaries"
> DATA "zt29_d00"
> STATUS DEFAULT
> TYPE POLYGON
> PROJECTION
> "init=epsg:26797"
> END
> LABELITEM "ZCTA"
> CLASS
> COLOR 254 0 0
> LABEL
> COLOR 60 60 60
> SHADOWCOLOR 218 218 218
> SHADOWSIZE 1 1
> TYPE TRUETYPE
> FONT arialhb
> SIZE 10
> ANTIALIAS TRUE
> POSITION CL
> PARTIALS FALSE
> MINDISTANCE 5
> BUFFER 4
> END
> OUTLINECOLOR 60 60 60
> SYMBOL 0
> END
> END
> LAYER
> NAME "credits"
> STATUS DEFAULT
> TRANSFORM FALSE
> TYPE ANNOTATION
> FEATURE
> POINTS
> 10 680
> END
> TEXT 'Made with Mapserver.'
> END
> CLASS
> LABEL
> TYPE BITMAP
> POSITION CR
> COLOR 0 0 0
> END
> END
> END
> END
> Thanks,
> Matt
