Python MapScript module still not found (today's summary)
Ryan, Adam
ARyan at CO.LINN.OR.US
Wed May 11 14:15:01 EDT 2005
I tried Emil's setup and ran into the same problems.
I downloaded from:
http://hobu.stat.iastate.edu/mapserver/build_output/5_11_2005
Two flavors: none.exe and full.exe
I could not import _mapscript on either. Running dependency walker I found
files could not be found by libmap.ddl:
Both flavors could not find:
LTI_DSDK_DLL.DLL
NCSECW.DLL
NCSUTIL.DLL
OCI.DLL
And full.exe could not find these and:
SDE90.DLL
So, I pulled LTI_DSDK_DLL.DLL off of
http://hobu.stat.iastate.edu/mapserver/build_output/sean_2003
Then I pulled the ECW SDK Dlls from Frank's Tools.
But I don't have SDE, and isn't the OCI.dll for the Oracle client? Should
that be referenced in the libmap.dll from none.exe?
I haven't searched around for OCI.dll. Shall I?
Cheers,
Adam
> -----Original Message-----
> From: Sean Gillies [mailto:sgillies at frii.com]
> Sent: Wednesday, May 11, 2005 9:20 AM
> To: Emil Zegers
> Cc: Mapserver ML; Adam Ryan
> Subject: Re: Python MapScript module still not found (today's summary)
> Emil,
> I'm sorry, but I don't have any experience with Python as a
> CGI on IIS.
> I'm cc'ing Adam Ryan directly on this because I think he has the
> know-how.
> Sean
> On May 10, 2005, at 3:30 PM, Emil Zegers wrote:
> > Hello,
> > After fiddling around some more I finally leave this case unresolved
> > for
> > today.
> > I switched to ActiveState ActivePython instead of using the binaries
> > from
> > www.python.org and reinstalled Python MapScript, no change.
> > Tried a lot of different mappings in IIS for .py files:
> > c:\python23\python.exe --> nothing works, time-out for all
> .py files
> > c:\python23\python.exe -u "%s" "%s" --> works for .py
> scripts, import
> > DLL gives 'not found'
> > c:\python23\python.exe "%s" --> works for .py scripts, import DLL
> > gives 'not
> > found'
> > c:\python23\python.exe "%s" "%s" --> works for .py scripts,
> import DLL
> > gives
> > 'not found'
> > Any ideas on what mapping to use and how this influences importing
> > dll's
> > will be appreciated.
> > So now under IIS I can run .py scripts under IIS and I can import
> > modules
> > (eg. importing os works fine) but I still have this problem with
> > importing
> > MapScript.
> > Importing MapScript from the Python command line works fine.
> > Could it be it has something to do with the naming of the MapScript
> > files?
> > There's a _mapscript.pyd and mapscript.py, mapscript.pyc and
> > mapscript.pyo
> > after installing.
> > For os module there is no .pyd, just the py, pyc and pyo (just a
> > guess, I'm
> > no Python expert)
> > On a Python mail list I also found some similair info about
> importing
> > problems under IIS and not with command line. They
> suspected the way
> > the files were installed may be (part of) the reason. I've installed
> > everything
> > with administrator rights and have granted IUR and IWAM all needed
> > rights.
> > Switching to Apache might be a really easy solution for this but I
> > would
> > like to have this working with IIS.
> > Regards,
> > Emil
