Python MapScript module still not found (today's summary)
Howard Butler
hobu at IASTATE.EDU
Wed May 11 17:11:08 EDT 2005
Adam,
The problem with my nightlies is that the GDAL used to make these has ECW
and MrSID and OCI (all of which I don't distribute). Please use the 4.4.2
"None" package on http://hobu.stat.iastate.edu/mapserver/ and let me know
how it goes.
thanks
Howard
At 04:04 PM 5/11/2005, Ryan, Adam wrote:
>Just an update. I pulled an OCI.dll off the Oracle site and that seems to
>work but I'm stuck on the ECW SDK dlls. I can't seem to find acceptable
>versions.
>Adam
> > -----Original Message-----
> > From: Ryan, Adam [mailto:ARyan at CO.LINN.OR.US]
> > Sent: Wednesday, May 11, 2005 11:15 AM
> > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > Subject: Re: [UMN_MAPSERVER-USERS] Python MapScript module
> > I tried Emil's setup and ran into the same problems.
> > I downloaded from:
> > http://hobu.stat.iastate.edu/mapserver/build_output/5_11_2005
> > Two flavors: none.exe and full.exe
> > I could not import _mapscript on either. Running dependency
> > walker I found files could not be found by libmap.ddl:
> > Both flavors could not find:
> > LTI_DSDK_DLL.DLL
> > NCSECW.DLL
> > NCSUTIL.DLL
> > OCI.DLL
> > And full.exe could not find these and:
> > SDE90.DLL
> > So, I pulled LTI_DSDK_DLL.DLL off of
> > http://hobu.stat.iastate.edu/mapserver/build_output/sean_2003
> > Then I pulled the ECW SDK Dlls from Frank's Tools.
> > But I don't have SDE, and isn't the OCI.dll for the Oracle
> > client? Should that be referenced in the libmap.dll from none.exe?
> > I haven't searched around for OCI.dll. Shall I?
> > Cheers,
> > Adam
> > > From: Sean Gillies [mailto:sgillies at frii.com]
> > > Sent: Wednesday, May 11, 2005 9:20 AM
> > > To: Emil Zegers
> > > Cc: Mapserver ML; Adam Ryan
> > > Subject: Re: Python MapScript module still not found
> > (today's summary)
> > > Emil,
> > > I'm sorry, but I don't have any experience with Python as a CGI on
> > > IIS.
> > > I'm cc'ing Adam Ryan directly on this because I think he has the
> > > know-how.
> > > Sean
> > > On May 10, 2005, at 3:30 PM, Emil Zegers wrote:
> > > > Hello,
> > > > After fiddling around some more I finally leave this case
> > unresolved
> > > > for today.
> > > > I switched to ActiveState ActivePython instead of using
> > the binaries
> > > > from www.python.org and reinstalled Python MapScript, no change.
> > > > Tried a lot of different mappings in IIS for .py files:
> > > > c:\python23\python.exe --> nothing works, time-out for all
> > > .py files
> > > > c:\python23\python.exe -u "%s" "%s" --> works for .py
> > > scripts, import
> > > > DLL gives 'not found'
> > > > c:\python23\python.exe "%s" --> works for .py scripts, import DLL
> > > > gives 'not found'
> > > > c:\python23\python.exe "%s" "%s" --> works for .py scripts,
> > > import DLL
> > > > gives
> > > > 'not found'
> > > > Any ideas on what mapping to use and how this influences
> > importing
> > > > dll's will be appreciated.
> > > > So now under IIS I can run .py scripts under IIS and I can import
> > > > modules (eg. importing os works fine) but I still have
> > this problem
> > > > with importing
> > > > MapScript.
> > > > Importing MapScript from the Python command line works fine.
> > > > Could it be it has something to do with the naming of the
> > MapScript
> > > > files? There's a _mapscript.pyd and mapscript.py,
> > mapscript.pyc and
> > > > mapscript.pyo
> > > > after installing.
> > > > For os module there is no .pyd, just the py, pyc and pyo (just a
> > > > guess, I'm no Python expert)
> > > > On a Python mail list I also found some similair info about
> > > importing
> > > > problems under IIS and not with command line. They
> > > suspected the way
> > > > the files were installed may be (part of) the reason.
> > I've installed
> > > > everything with administrator rights and have granted IUR
> > and IWAM
> > > > all needed rights.
> > > > Switching to Apache might be a really easy solution for
> > this but I
> > > > would like to have this working with IIS.
> > > > Regards,
> > > > Emil
