in-process vs. over the wire map generation for simple GUI app
Joseph Bussell joe at OTSYS.COM
Wed May 11 17:38:25 EDT 2005
Greetings Listers,
   What would folks use when an application must produce maps as a side
effect?  Would you go for an in-process map generation method?   If so,
what would you use?  Alternatively, would you use a mapserver backend
that the local process would communicate with?  Any thoughts would be
appreciated.
Cordially,
Joe Bussell
On Time Systems
