Projection Problem
    Frank Warmerdam
    fwarmerdam at GMAIL.COM
    Wed May 11 19:44:21 PDT 2005
On 5/11/05, William Hamouz <william.hamouz at phoenix.gov> wrote:
> <OGRVRTDataSource>
>  <OGRVRTLayer name="Incidents">
>   <SrcDataSource>ODBC:UNITSTATUS</SrcDataSource>
>                 <SrcLayer>Incidents</SrcLayer>
>                 <GeometryType>wkbPoint</GeometryType>
>                 <LayerSRS>WGS84</LayerSRS>
>                 <GeometryField encoding="PointFromColumns" x="Lat"
> y="Long"/>
>          </OGRVRTLayer>
> </OGRVRTDataSource>
Will,
I didn't look over your whole configuration carefully, but I suspect
your problem is in using Lat for "x" and Long for "y".  Assuming that
Lat is latitude and Long is longitude you should have x="Long", y="Lat".
Best regards,
More information about the MapServer-users
