Warnings with UNIX build - undefined functions
Bob Bruce covariance at SHAW.CA
Wed May 11 23:36:01 EDT 2005
I should have mentioned that my configure command is:
./configure --with-php=/usr/local/php/include/php
--with-php-regex-dir=/usr/src/php-4.3.11 --with-proj=../proj-4.4.9
--with-wfsclient --with-ogr=../gdal-1.2.6 --with-gdal=../gdal-1.2.6
sorry about that.
   Bob Bruce
On Wed, 11 May 2005 22:19:19 -0500, Bob Bruce <covariance at SHAW.CA> wrote:
>I am trying to build MapScript on a Debian UNIX system and am getting an
>module that crashes when I am trying to create imagemaps. And it is weird
>because the same source code works fine on my Windows 2000 Pro system.
>So I have closely scrutinized the build messages on the UNIX system and see
>some warnings that I'm not getting on my Windows system, these are:
>mapwms.c: In function `msWMSGetStyles':
>mapwms.c:2762: warning: implicit declaration of function `msSLDGenerateSLD'
>mapwms.c:2762: warning: assignment makes pointer from integer without a cast
>mapscript_i.c: In function `mapObj_applySLD':
>mapscript_i.c:381: warning: implicit declaration of function `msSLDApplySLD'
>mapscript_i.c: In function `mapObj_applySLDURL':
>mapscript_i.c:385: warning: implicit declaration of function `msSLDApplySLDURL'
>mapscript_i.c: In function `mapObj_generateSLD':
>mapscript_i.c:390: warning: implicit declaration of function `msSLDGenerateSLD'
>mapscript_i.c:390: warning: return makes pointer from integer without a cast
>mapscript_i.c: In function `layerObj_generateSLD':
>mapscript_i.c:589: warning: return makes pointer from integer without a cast
>these functions are defined in the file: php_mapscript.h
>and in this file the following statements enclose the definition of these
>functions:
>#ifndef _PHP_MAPSCRIPT_H_INCLUDED_
>#define _PHP_MAPSCRIPT_H_INCLUDED_
>#endif /* _PHP_MAPSCRIPT_H_INCLUDED_ */
>I cannot find the value _PHP_MAPSCRIPT_H_INCLUDED_ defined anywhere and I am
>mistified as to why these function definitions don't seem to be reached. Do
>you have any ideas?
>thanks,
>       Bob Bruce, Winnipeg, Manitoba
