Precompiled binaries for mapscript c#
Jean David TECHER davidtecher at YAHOO.FR
Thu May 12 06:54:05 EDT 2005
Hi alone,
as I've done for c# support, you could compile it on a linux box (as all the good things ;c) ). BUT in order to do that what is the requierment ? You need to have mono on your fc3. If you have also a gentoo box (which is the greater distro ... I think) I've made an ebuild for it you could find on the gentoo bugzilla or from this page :
http://www.01map.net/gentoo/ . For fc3 rpms you could use our installer (in french only for the moment, if you would like to translate it in english I'll be happy ;) ) but it include a mapserver without the c# support, so I'm not sure you enjoy this rpm :/ We've also made an installer which is freely available on our web server here : http://www.01map.net/redhat (as the rpms).
For more informations you could just read the ebuild here : http://www.01map.net/gentoo/sci-geosciences/mapserver/mapserver-4.4.2.ebuild. In this ebuild you could see all the configuration options and more, how I compile the mapscript c# support and its requierments (just remplace in your mind mono by c# and you have the solution).
Hope that help.
Have a nice day.
Cordialy.
Le 12 mai 05, à 11:45, Rainer Spittel a écrit :
  Hi folk,
  I would like to test the mapscript c# combination and tried to compile the
  mapserver. I think I am totally wrong, because I use a Linux server and I
  try to get windows binaries...
  I get compiler errors when I try to compile the csharp extension on my
  fedora 3 server:
  /usr/local/bin/swig -csharp -o mapscript_wrap.c ../mapscript.i
  gcc -fpic -c -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG
  -DUSE_GD_TTF -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
  -DGD_HAS_GDIMAGEGIFPTR mapscript_wrap.c
  gcc -fpic -shared mapscript_wrap.o -o libmapscript.so -L../.. -lmap -lgd
  -L/usr/local/lib -lgd -ljpeg -lttf -lpng -lz -ltiff -ljpeg -lpng -lz -ljpeg -lm
  mcs /t:library /out:mapscript_csharp.dll *.cs
  /bin/sh: mcs: command not found
  make: *** [mapscript_csharp] Error 127
  And I am sure that this won't create the .net library for windows... ;-)
  Are precompiled binaries for windows available, similar to the ms4w
  project? Is a HowTo introduction available? This libraries are required to
  compile the csharp api?
  Thanks
  Rainer
Gérald Fenoy
!! GIS for gentoo'er !!
Gérald Fenoy
TECHER Jean David
01MAP
e-mail: david at 01map.net
Tél: 04 67 45 60 27
Entreprise: http://www.01map.net
Perso: http://techer.pascal.free.fr/postgis/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050512/5caadfd2/attachment.html
