GetMap and browse
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Thu May 12 09:16:31 EDT 2005
What is your exact mode=browse request? Are you using layers=...... ?
Only layers with STATUS DEFAULT appear in the image when you don't specify them as a layer in the layers parameter.
Best regards,
Bart
Syncera-ITSolutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Vincent Da-Col <vincedacol at FREE.FR> 05/12/05 02:43pm >>>
Hello,
I have applie a Getmap request on a Map file. All is OK, my map appear on the
sceen.
But when I try to post on the screen this same map with a simple "browse" mode,
nothing appear.
The Getcapabilities work fine, with no warning.
In copy, my mapfile:
MAP
NAME Europe_France_WGS84
EXTENT -34.5523788 26.2114230 72.2516881 83.340374
#EXTENT -180 -180 180 180
#EXTENT -760555 -1058700 4505870 3245049
#EXTENT -5140.02940964483 1562890.02666348 1250740.05344726 2734710.03129094
IMAGETYPE gif
SIZE 800 600
SHAPEPATH "./data"
IMAGECOLOR 200 255 255
PROJECTION
"init=epsg:4326"
END
DEBUG ON
OUTPUTFORMAT
NAME gif
MIMETYPE "image/gif"
DRIVER "GD/GIF"
EXTENSION "gif"
IMAGEMODE PC256
TRANSPARENT FALSE
END
##WEB##
WEB
log "/tmp/Europe_WGS84.log"
IMAGEPATH "./tmp/"
TEMPLATE 'Donnees_test_WMS_WFS_template.html'
IMAGEURL "http://10.133.110.29/WMS/Europe_WGS84/tmp/"
METADATA
"wms_title" "Europe_France_WGS84"
"wms_onlineresource"
"http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/WMS/Europe_WGS84/test3.map&"
#"wms_srs" "epsg:4326"
END
END
##Europe##
LAYER
NAME "Europe_WGS84"
DATA "Europe_region"
STATUS ON
TYPE POLYGON
METADATA
"wms_title" "Europe_WGS84"
END
CLASS
COLOR 241 231 193
OUTLINECOLOR 32 32 32
END
PROJECTION
#"init=epsg:4326"
#"init=epsg:2383"
END
END
##France##
LAYER
NAME "France_WGS84"
DATA "France_region"
STATUS ON
TYPE POLYGON
METADATA
"wms_title" "France_WGS84"
END
CLASS
COLOR 241 0 193
END
PROJECTION
#"init=epsg:4326"
END
END
END
Thanks for the help,
Vincent Da-Col
