Mapserver extent and projection
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Fri May 13 04:23:44 EDT 2005
it is possible with Mapserver to do reprojection.
Use a PROJECTION object in your MAP object for the output map projection that you want.
Use a PROJECTION object for every LAYER stating the source projection of the layer.
Best regards,
Bart
Syncera-ITSolutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Vincent Da-Col <vincedacol at FREE.FR> 05/13/05 10:13am >>>
Hello,
I'm really new to the world of mapserver. I work on it since 2 week. I like
working on this great programme, but I have a little probleme with the extent
and different projections.
I have 2 layers:
- one in Lambert II projection (EXTENT -760555 -1058700 4505870 3245049)
- the other in WGS84 projection (EXTENT -34.5523788 26.2114230 72.2516881
83.340374)
So How could I dislay the two layers together in mapserver?
Must I reproject one layer in arcgis, or is it possible directly with mapserver?
Thank for the help,
Vincent Da-Col
