A long time to render a white picture with PHP/Mapscript...
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Fri May 13 05:09:08 EDT 2005
Do you have a spatial index on your PostGIS table and is it being used?
Best regards,
Bart
Syncera-ITSolutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Philippe Gondek <philippe.gondek at GMAIL.COM> 05/13/05 11:04am >>>
Here is my script :
<?php
// Philippe GONDEK
// SCRIPT PHP QUI SE CONNECTE A UNE BASE POSTGRESQL AFIN DE RECUPERER
// DONNEES SPATIALES POUR ENSUITE PERMETTRE A MAPSERVER DE CALCULER
// L'IMAGE QUE NOUS AFFICHERONS.
// PARAMETRES POUR LA CONNEXION AU SERVEUR POSTGRESQL
dl('php_mapscript.so');
$hote = "localhost"; //OK
$base_de_donnees = "lemiam"; //OK
$utilisateur = "phil"; //OK
$mot_de_passe = "1707loulou442"; //OK
$table_choisie = "regions"; //OK
// PARAMETRES POUR PhpMapScript
$Path_Mapfile = "/var/www/localhost/htdocs/miam/";
$Nom_Mapfile = "miam.map";
//longueur de l'image a generer. La hauteur de l'image sera calculee
//selon la longueur
$longueur_image_mapfile = "500";
//chemin d'acces absolu vers le repertoire contenant l'image a generer
$mapserver_imagepath = "/var/www/localhost/htdocs/miam/tmp/";
//URL locale selon le chemin d'acces specifie pour l'image
$mapserver_imageurl = "/miam/tmp/";
//nom de la donnee attributaire a afficher
//celle-ci correspond a une colonne dans la table choisie
$mapserver_labelitem = "region"; //OK
// CONNEXIONS AU SERVEUR POSTGRESQL
$db_handle = pg_Connect ("host=localhost port=5432 dbname=lemiam
user=phil password=1707loulou442");
/*pg_connect("host="$hote
" dbname="$base_de_donnees
" user="$utilisateur
" password="$mot_de_passe);*/
//selectionner le champ spatial associe a la table choisie
$pgsql_colonne_spatiale = "
select f_geometry_column,type
from geometry_columns
where f_table_name like '".$table_choisie."'";
$pgsql_resultat = pg_exec($db_handle,$pgsql_colonne_spatiale);
$colonne_spatiale = pg_result($pgsql_resultat,0,0);
$type_donnee = pg_result($pgsql_resultat,0,1);
$type_donnee_pour_mapserver = str_replace("LINESTRING",
MS_LAYER_LINE,
str_replace("MULTILINESTRING",
MS_LAYER_LINE,
str_replace("MULTIPOLYGON",
MS_LAYER_POLYGON,
pg_result($pgsql_resultat,0,1))));
// Calcul de l'extent pour MapServer
// et de la hauteur de l'image
$pgsql_extent = "select
xmin(extent(".$colonne_spatiale.")),
ymin(extent(".$colonne_spatiale.")),
xmax(extent(".$colonne_spatiale.")),
ymax(extent(".$colonne_spatiale.")) from
".$table_choisie;
$resultat_extent = pg_exec($db_handle,$pgsql_extent);
$xmin = pg_result($resultat_extent,0,0);
$ymin = pg_result($resultat_extent,0,1);
$xmax = pg_result($resultat_extent,0,2);
$ymax = pg_result($resultat_extent,0,3);
$longueur_extent = abs($xmax-$xmin);
$hauteur_extent = abs($ymax-$ymin);
$rapport_extent = $longueur_extent / $hauteur_extent;
$hauteur_image_mapfile = $longueur_image_mapfile / $rapport_extent;
// CREATION DE LA MAP
$map = ms_newMapObj("miam.map");
//echo nl2br("\n ms_newMapObj :
$map->name");////////////////////////////////////////////////////////
$map->setextent($xmin,$ymin,$xmax,$ymax);
$map->web->set("imagepath",$mapserver_imagepath);
$map->web->set("imageurl",$mapserver_imageurl);
$map->set("width",$longueur_image_mapfile);
$map->set("height",$hauteur_image_mapfile);
// Ajout d'une couche
$layer = ms_newLayerObj($map);
// Nom de la couche conforme a celui de la base de donnees
$layer->set("name",$base_de_donnees);
$layer->set("status",MS_ON);
// Connexion a la base de donnees PostGIS
$layer->set("connectiontype",MS_POSTGIS);
$layer->set("connection","host=localhost port=5432
dbname=lemiam user=phil password=1707loulou442");
// Requete spatiale utilisee
$layer->set("data","the_geom from regions");
// Precision sur le type de donnee spatiale a prendre en compte:
//LINE, POINT...
$layer->set("type",$type_donnee_geometrique_pour_mapserver);
// Nom de la colonne de donnees attributaires a afficher
$layer->set("labelitem",$mapserver_labelitem);
// Ajout de la class
$class = ms_newClassObj($layer);
// Ajout du Label
$label = $class->label;
// Precision sur l'affichage de la donnee de type attributaire
// la couleur, la taille de la donnee ...
$label->set("position",MS_CC);
$label->color->setRGB(0,0,0);
$label->outlinecolor->setRGB(255,255,255);
$label->shadowcolor->setRGB(255,255,255);
$label->backgroundcolor->setRGB(255,255,255);
$label->backgroundshadowcolor->setRGB(255,255,255);
// Ajout du style
$style = ms_newStyleObj($class);
// Precision sur l'affichage des donn?es spatiales
// couleur de bourdure en code 128 0 0 pour RGB
$style->set("size",4);
$style->outlinecolor->setRGB(128,0,0);
// Utilisation de PhpMapScript
// pour generer l'image associee a la mapfile au format PNG
$image = $map->draw();
$image_url = $image->saveWebImage(MS_PNG,1,1,0);
// Fermeture de la connexion a PostgreSQL
pg_close($db_handle);
<html>
<body>
<!-- AFFICHAGE DE L'IMAGE -->
<img src=<?php echo "'http://localhost".$image_url."' width='".$map->width.
"px' height='".$map->height."px'";?>/>
</body>
</html>
I dont know why but the picture I render is white and it takes a long
time... Approximately 2 minutes... Is there a reason???
