About ShapeTree and Raster TileIndex {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Fri May 13 17:21:06 EDT 2005
Dear Akio,
TILEINDEX should refere to the shape file crreated by gdaltindex
I have read a thread on the list, do not append extension to the
name of the shape because it will search for name.shp.qix file as
spatial index. To tell you the truth I have no check the performance yet.
Zoltan
On Fri, 13 May 2005, Akio Neuchi wrote:
> Hello to all,
> I just made a *.qix file from *.shp file for Raster TileIndex images --
> around 800 gif images,
> and tested with and without shape tree. The result was there is no
> difference in processing speed.
> The procedure was,
> gdaltindex MSRAS_12000.shp MSRAS_12000/*.gif,
> shptree MSRAS_12000.shp,
> and I got MSRAS_12000.qix.
> (Under MSRAS_12000 directory there are 800 gif and wld files.)
> I wonder if I am following the right procedure, and if so,
> why there is no difference on the processing.
> In addition, I have around 100 of Vector TileIndex shape directories,
> and If ShapeTree really works, I am planning to build *.qix for each Vector
> shapes.
> My OUTPUTFORMAT amd Raster layer are like these:
> OUTPUTFORMAT
> NAME gif
> MIMETYPE "image/gif"
> DRIVER "GD/GIF"
> EXTENSION "gif"
> IMAGEMODE RGB
> # IMAGEMODE PC256
> TRANSPARENT FALSE
> FORMATOPTION "INTERLACE=OFF"
> END
> ### RASTER Layer
> LAYER
> NAME "MSRAS_12000"
> GROUP "B_RASTER"
> TILEINDEX "MSRAS_12000.qix"
> # TILEINDEX "MSRAS_12000.shp"
> TILEITEM "Location"
> TYPE RASTER
> # STATUS ON
> STATUS DEFAULT
> MINSCALE 50
> MAXSCALE 5000000
> PROJECTION
> "proj=latlong"
> # "init=epsg:26915"
> END
> END
> Thank you for your suggestions.
> Akio
