Label Coloring
David Robnett
David.Robnett at NOAA.GOV
Mon May 16 12:43:45 EDT 2005
Hi list,
I am trying to map data from a csv file using php mapscript. I would
like be able to color the label text based on values within the csv
file. I have previously used expressions in the class object and a
classitem to do this with spatial data and was hoping there is a similar
method for the csv file. I get the data plotted by creating line
objects and adding them as a feature to the layer but coloring them
according to different values has me stumped. My only thought so far
has been to create different layers with each one having a single class
and label object with the color set to my specs. This seems like it is
very inefficient and non-extensible way to do this. Any hints or
pointers in the right direction would be appreciated.
Thanks,
Dave
