Image transparency via SWIG API
Rick Innis
rick at INNIS.CA
Mon May 16 20:54:07 EDT 2005
> Rick, you say everything works fine when you load the same layer via a
> mapfile ... so why not do that?
The application allows each user, or group of users, to view different
data layers superimposed on the same base map. This is running as a web
service, so we don't want to have to manage potentially hundreds or
thousands of maps that differ only in one or two layers.
> I'm going to need more details on your
> use before I can be of any help such as how you are styling and
> rendering the points, and perhaps the relevant portion of the mapfile
> that works.
OK, and thanks. In reverse order, then, here's the mapfile fragment:
LAYER
NAME user_data
STATUS on
CONNECTION "user=XXXX password=YYYY dbname=ZZZZ
host=localhost port=5432"
CONNECTIONTYPE postgis
DATA "the_geom from j_random_table"
TYPE point
CLASS
NAME "pins"
STYLE
BACKGROUNDCOLOR 0 255 0
COLOR 0 255 0
SYMBOL ../../Image/Pin/pin_black_map.gif
END
END
END
And the code:
// Corresponds to the LAYER statement above
layerObj l = new layerObj(map);
l.setType(MS_LAYER_TYPE.MS_LAYER_POINT);
l.setConnectiontype(MS_CONNECTION_TYPE.MS_POSTGIS);
l.setConnection(connectionString);
l.setData(geomString);
l.setStatus(mapscriptConstants.MS_ON);
l.setName("data_layer");
// corresponds to CLASS statement
classObj c = l.getClass(0);
// paranoia?
if (c == null)
c = new classObj(l);
// this seems to be needed in the API version of this
c.setStatus(mapscriptConstants.MS_ON);
// create a symbolObj and insert it into the map's symbol set
symbolObj so = new symbolObj("pin",pinPath);
symbolSetObj ss = map.getSymbolset();
ss.appendSymbol(so);
// create a style object to attach the symbol to
styleObj style = new styleObj(c);
style.setSymbol(1);
style.setSymbolname("pin");
I've also attached the resulting map, though I'm not sure if the list
will strip it or not.
Thanks for any insight you can provide. In my perfect world the
solution is something simple, even if not obvious :-)
--Rick.
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050516/cddd3eb3/map9561.png
