SWIG Mapscript: Checking for label object
Sean Gillies sgillies at FRII.COM
Wed May 18 16:23:49 EDT 2005
On May 18, 2005, at 11:59 AM, Ryan, Adam wrote:
> Mapscripters,
> Labels are drawn for a class with as little as 'LABEL END' in the map
> file.
> That's pretty cool.
> But how can I tell, using mapscript, if such a label is defined?
> classObj.label returns an object regardless.
> Hints?
> Adam
Adam,
That's right, all classObjs have a default label.  Whether or not a
class is labeled depends on the parent layer's labelitem.
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
