using LoadQuery( ) via MapScript
Rhys Ickeringill
rhysi at OMNILINK.COM.AU
Thu May 19 01:19:49 EDT 2005
Hello again list
Quick question: how can I make use of LoadQuery( )? What does it do? The
only examples I can find are all of the form:
map.loadQuery( filename )
map.drawQuery( )
Is this all you can do with loadQuery( )? Can I access information such as
what layer(s) the query related to? Can I somehow get it populate the
ResultCacheMember object of the layer(s) in which the (saved) query results
were located?
Thanks
- Rhys
