Image Tiling
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Thu May 19 18:19:45 EDT 2005
I use imagemagick and gdal_translate to split and build tiles from large
images. Then I build a tile index with gdaltindex. As long as you tile
index layers MIN/MAX scales are set right you get a pretty big
performance gain. However if you're rendering many of the tiles in the
same image it slows down. I create overviews for large scales and
display those and have the tile index only come on at lower scales.
-e
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Greg Taylor
Sent: Thursday, May 19, 2005 1:42 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Image Tiling
What kind of programs/scripts do most of you use to tile .tif images?
I'd be interested in playing with this. Do any of you that use tiled
images notice an improvement in performance?
