JOIN object and WMS/WFS
Emil Zegers
taatuut at PLANET.NL
Fri May 20 08:25:56 EDT 2005
Hello Tom,
I don't think it is possible to do joins this way and access them through
WMS/WFS.
In the past I've asked a similair question whether it is possible to
classify and display a map image based on attributes in the join table by
using the MapServer JOIN.
That is not possible (see bug
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=674).
But maybe doing a join through OGR will work for you (I have not tested this
myself).
OGR SQL supports a limited form of one to one JOIN.
Somehting like:
CONNECTIONTYPE OGR
CONNECTION "data/popplace_pt"
DATA "SELECT columns FROM table LEFT JOIN some join statement"
Take a look at the JOIN examples at
http://www.remotesensing.org/gdal/ogr/ogr_sql.html
Regards,
Emil
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Kralidis,Tom [Burlington]
Sent: vrijdag 20 mei 2005 14:01
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] JOIN object and WMS/WFS
Some further progress. I can verify that MapServer is recognizing the
join; I put invalid entries for the TABLE, FROM, and TO directives and
got a MapServer error, so I know the join'd table is being read, or at
least scanned for existence/fields.
Any suggestions? Is it possible to do JOIN's in this way and have them
accessible via WMS/WFS?
Thanks
..Tom
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of
> Sent: Tuesday, 17 May, 2005 07:44
> Subject: [UMN_MAPSERVER-USERS] JOIN object and WMS/WFS
> Hi,
> I have a .shp/.shx/.dbf combo which I have publised as a
> layer/featuretype for OGC:WMS/OGC:WFS.
> I have an additional .dbf file which I'd like to join to the
> layer. However when I issue a WMS GetFeatureInfo WFS
> DescribeFeatureType I can't see the data from the seperate .dbf file.
> Any suggestions? Below is my mapfile layer def:
> Thanks in advance
> ..Tom
> LAYER
> NAME "popplace_pt"
> STATUS ON
> DATA "data/popplace_pt"
> TYPE POINT
> DUMP TRUE
> HEADER "templates/popplace_pt_query_header.html"
> TEMPLATE "templates/popplace_pt_query_body.html"
> TOLERANCE 30
> JOIN
> NAME "POPNAMEJOIN"
> FROM "POPNAME"
> TO "POPNAME"
> TABLE
> "/usr/local/wwwsites/apache/devgeo.cciw.ca/apps/mapserv/servic
> es/kyw/dat
> a/table1.dbf"
> TYPE MULTIPLE
> TEMPLATE "templates/popplace_pt_join_query_body.html"
> END
> METADATA
> "ows_title" "Populated Places"
> "ows_abstract" "Populated Places"
> "ows_keywordlist" "environment,air pollution,acid
> rain,climate,greenhouse effect,ecosystems,environment i mpact
> assessment,emergency preparedness,pollution,biological
> diversity,environmental protection,water,wildli
> fe,weather,waste,environmental management,environmental
> technology,recycling,climate change,environmental em
> ergency,pollution prevention,sustainable development,science
> and technology,environmental action,smog,ozone, ec,cise,ogc,cgdi"
> "wms_opaque" "0"
> "ows_metadataurl_type" "FGDC"
> "wms_metadataurl_format" "text/html"
> "ows_metadataurl_href" "http://www.environmentandresources.ca/"
> "wms_dataurl_format" "text/html"
> "wms_dataurl_href" "http://www.environmentandresources.ca/"
> "wfs_metadataurl_format" "TXT"
> "gml_include_items" "all"
> END
> PROJECTION
> "init=epsg:42304"
> END
> LABELITEM "REAL_NAME"
> CLASS
> NAME "Populated Places"
> SYMBOL 'circle'
> SIZE 3
> COLOR 0 255 0
> LABEL
> ANTIALIAS TRUE
> COLOR 255 0 0
> POSITION ur
> SIZE LARGE
> END
> END
> END
