Easy $100.00 for the working example
Aaron Racicot
aaronr at ECOTRUST.ORG
Mon May 23 13:43:09 EDT 2005
Dave,
Check out:
http://pearl.ecotrust.org/apps/simple_mapserver/index.phtml
I have added your two data layers to the example I made for you and
shifted the extent to view those layers. I am using the tiff version of
both rasters, as I don't have any experience getting HDF working with
Mapserver. I made a world file for the Bathymetry layer since it did
not have any geo-referencing info in the image. You will need this to
tell Mapserver (and GDAL) where this image is and what the resolution
is. I have copied in the Mapfile and .tfw file below for your
reference. Let me know if this helps. I will leave it to others for
help on the HDF file format and defining that layer with Mapserver and
GDAL.
Aaron
The Bathymap.tfw file
[aaronr at pearl nc_fish]$ more Bathymap.tfw
0.00151209677419
0
0
-0.00125549278092
-78.9992439516
34.9993722536
The new Mapfile with the layers you provided
#################### E c o t r u s t ####################
## Jean Vollum Natural Capital Center ##
## 721 NW Ninth Avenue ##
## Suite 200 ##
## Portland, OR 97209 ##
## www.ecotrust.org ##
## Copyright 2005, Ecotrust ##
MAP
NAME "Simple Test"
STATUS ON
EXTENT -91 22 -70 37
SIZE 800 600
SHAPEPATH "/var/www/html/apps/simple_mapserver/data"
SYMBOLSET "/var/www/html/apps/simple_mapserver/etc/symbols.sym"
FONTSET "/var/www/html/apps/simple_mapserver/etc/fonts.txt"
IMAGETYPE gif
IMAGECOLOR 255 255 255
UNITS DD
WEB
IMAGEPATH "/tmp/ms_temp/"
IMAGEURL "/tmp/ms_temp/"
METADATA
END
END
QUERYMAP
STATUS OFF
SIZE -1 -1
COLOR 255 255 0
STYLE HILITE
END
PROJECTION
"proj=latlong"
"datum=WGS84"
END
# Start of reference map
REFERENCE
"/var/www/html/apps/simple_mapserver/data/blue_marble_us_200_150.gif"
EXTENT -170 10 -64 90
SIZE 200 150
STATUS OFF
MINBOXSIZE 1
MAXBOXSIZE 200
COLOR -1 -1 -1
OUTLINECOLOR 255 255 255
MARKERSIZE 10
MARKER 'star'
END
LEGEND
STATUS OFF
POSITION LL
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
TYPE BITMAP
SIZE MEDIUM
OFFSET 5 5
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
PARTIALS TRUE
FORCE FALSE
END
END
SCALEBAR
STATUS ON
COLOR 100 100 100
IMAGECOLOR 217 217 217
UNITS MILES
INTERVALS 2
SIZE 200 3
STYLE 1
POSITION LL
INTERLACE TRUE
LABEL
TYPE BITMAP
SIZE MEDIUM
OFFSET 5 5
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
PARTIALS TRUE
FORCE FALSE
END
END
LAYER
NAME "NOAA SST - TIF"
DATA "./nc_fish/2005_118_0843_n16_sr.tif"
SIZEUNITS PIXELS
STATUS DEFAULT
TOLERANCE 0
TOLERANCEUNITS PIXELS
TYPE RASTER
UNITS DD
PROJECTION
"AUTO"
END
END
LAYER
NAME "Bathy - TIF"
DATA "./nc_fish/Bathymap.tif"
SIZEUNITS PIXELS
STATUS DEFAULT
TOLERANCE 0
TYPE RASTER
UNITS DD
PROJECTION
"proj=latlong"
"datum=WGS84"
END
END
END
-----Original Message-----
Sent: Friday, May 20, 2005 4:41 PM
To: Aaron Racicot
Subject: [spamcatcher] Re: [UMN_MAPSERVER-USERS] Easy $100.00 for the
working example
Greetings Aaron,
Thank you for your help. It is most kind of you to share your work
with
me. I worked with it for a while today. After an hour or so of messing
with it.....I think that my OS is what is causing the problems. A week
or
so ago I switched from Mandrake to HostGIS. Over all it seems to be a
pretty good setup for folks like me with limited Linux experience.
