layer.queryByPoint( ) and layer.open( ) interoperation
Rhys Ickeringill
rhysi at OMNILINK.COM.AU
Mon May 23 20:40:11 EDT 2005
Hi List,
Is the following an undocumented feature or a bug?
I had Mapscript code which looked something like:
layer = map.getLayerByName( name )
layer.open( )
for( i = 0; i < points.length(); ++i ){
if( layer.queryByPoint( points[i], MS_SINGLE, 0 ) ){
result = layer.getResult( 0 )
shp = layer.getShape( result.tileindex, result.shapeindex )
info = shp.values
layer.close( )
But kept getting the MapServer errors to the effect "layer has not been
opened" on the call to layer.getShape( ). Playing with it, I found that the
following code gave the functionality I was after:
layer.open( )
info = shp.values
layer.close( ) // possibly redundant
This leads me to believe that each call to layer.queryByPoint( ) is having
the effect of layer.close( ). So - bug or feature?
Regards,
Rhys
