search tool
Michael Smith
msmith at SANANGELOMPO.ORG
Thu May 26 10:48:45 EDT 2005
I am just using mapserver. I do have php installed. Would I just create a
page using your script or insert it inside of my map html file?
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Kristjan Annus
Sent: Thursday, May 26, 2005 9:27 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] search tool
Are you using just mapserver or some scripting language ie. PHP as well?
Here is the PHP code witch I use to locate address names from shape and
deliver it to the user in a form of html - table, so that he can choose one
for output to the map.
$mySearchLayer = $map->getLayerByName("krundipiirid");
$mySearchLayer->set("status", 1);
$qstring = "('[Nimi]' =~ /".$otsiaadr.".*/)";
@$mySearchLayer->queryByAttributes("Nimi",$qstring
,MS_MULTIPLE);
if ($mySearchLayer->getNumResults()>0) {
$mySearchLayer->open();
for ($i=0; $i<$mySearchLayer->getNumResults(); $i++) {
$myResult = $mySearchLayer->getResult($i);
$myShape =
$mySearchLayer->getShape($myResult->tileindex,$myResult->shapeindex);
$myShapeExtent = $myShape->bounds;
echo '<tr><td bgcolor=#BBBBBB><a href="#"
onclick="window.document.kaardivorm.objekt.value=\''.$myResult->tileindex.';
'.$myResult->shapeindex.'\';window.document.kaardivorm.submit();return
false;">';
echo $myShape->values['NIMI'];
echo '</a></td></tr>';
} else {
print 'no objects';
Kristjan
>Hi List,
>I am working a implementing mapserver in our local govt. I have it up
>and running. Can anyone provide a template or example of how to search
>for a street and have mapserver zoom to that area? Thanks.
>Mike
