Mapscript .NET, compile
Sean Gillies
sgillies at FRII.COM
Thu May 26 17:41:35 EDT 2005
On May 26, 2005, at 11:40 AM, Bart van den Eijnden wrote:
> Hi list,
> I finally tried to compile Mapscript .NET and I thought I'd share the
> process I went through and ask a few questions. Let me start with the
> questions :-) :
> 1) why won't the generated mapscript_wrap.c file compile out of the box
> (see below)?
Bart, you're leaving out some crucial information ... which MapServer
version is this? I don't see the call to msSetup in mapscript_wrap.c
with 4.6beta2. I'm using SWIG 1.3.21 and testing with Mono.
> 2) what is the difference between mapscript.dll and
> mapscript_csharp.dll?
I did a 'strings mapscript.dll' ... it contains the functions of
libmap. The csharp dll is the C# wrapper module.
> 3) using the utilities eg shpdump I do get a few unhandled exceptions.
> Is
> that supposed to be the case?
> Shape 1 has 1 part(s)
> bounds (362153.9375, 3651581.75) (413756.1875, 3708708)
> Unhandled Exception: System.NullReferenceException: Object reference
> not
> set to
> an instance of an object.
> at ShapeDump.Main(String[] args)
No, I don't think it should raise exceptions.
I'm not a C# user at all, but I am able to get the module in 4.6beta to
compile without warnings on Linux using the Makefile.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
