Windows Install {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Fri May 27 04:42:47 EDT 2005
Hi Patrick,
I have two php version on my linux box, one is an apache module and
the other is used ascgi for phpmapscript.
I changed the apache config file .phtml files are interpreted by
cgi version of php and .php files are interpreted by the apache module.
I suppose something similar can be done in iis too.
Bye
Zoltan
On Thu, 26 May 2005, Patrick Vogelaar wrote:
> Hello there,
> I'm definitely new to Mapserver and am interested in building an
> interactive web app using PHP/Mapscript.
> I have downloaded both:
> mapserver-4.6.0-beta2-win32-php4.3.11.zip
> as well as the MS4W package:
> ms4w_1.1.zip
> , both from http://maptools.org/ms4w/index.phtml?page=downloads.html
> I am running Windows 2000 Pro with IIS and I already have PHP 4.1.1
> installed. I know I need atleast PHP version 4.3.0 to run the gd library
> needed by Mapserver, but I have a large intranet already running the
> installed PHP and I'm wondering if it will cause something to crash or
> otherwise misbehave.
> Should I be concerned about the web apps I already have running or the
> intranet as a whole. If I install the MS4W package in a root directory like
> it says will there be two different versions of PHP on my server? And if
> so, which version will process my php scripts. Any help just getting me
> started would be greatly appreciated.
> Thanks,
> Patrick Vogelaar
