OGR Join and class {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Fri May 27 17:17:20 EDT 2005
Hi Alberto,
Thanks for your suggestion.
Changing the table name results "Invalid Fiels name: kafold.MYCOL"
Bye
Zoltan
On Fri, 27 May 2005, Alberto Gomez wrote:
> Hi Siki,
> Try to replace
> > CLASSITEM "ms.MYCOL"
> by CLASSITEM "kafold.MYCOL"
> I hope this help,
> Alberto
> ----- Original Message -----
> From: "Siki Zoltan" <siki at AGT.BME.HU>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Thursday, May 26, 2005 10:55 PM
> Subject: [UMN_MAPSERVER-USERS] OGR Join and class {Scanned}
> > Hi,
> > I would like to define classes based on an OGR Joined (ODBC) column.
> > I was not able to make the class definitions.
> > My layer definition looks like:
> > LAYER
> > NAME test
> > CONNECTIONTYPE OGR
> > CONNECTION kafold.shp
> > DATA "SELECT kafold.*, ms.* FROM kafold LEFT JOIN
> > 'ODBC:admin/xxx at mydb'.ms ON kafold.hrsz=ms.hrsz"
> > TYPE POLIGON
> > STATUS DEFAULT
> > CLASS
> > EXPRESSION /x/
> > COLOR 255 0 0
> > OUTLINECOLOR 0 0 0
> > END
> > END
> > If I remove CLASSITEM and EXPRESSION line the layer is drawn, so the DATA
> > definition is good.
> > I also tried to to remove CLASSITEM and give an expression like
> > EXPRESSION ('[ms.MYCOL]' = 'x')
> > I get an error massage in the apache error log
> > libpng warning Incomplete compressed datastream in iCCP chunk
> > Any idea?
> > Thanks
> > Zoltan
