Mapscript API: for object manipulation, not object creation?
Rick Innis
rick at INNIS.CA
Mon May 30 19:19:37 EDT 2005
> I'm looking at mapObj.java generated using SWIG 1.3.21 and
> MapServer 4.4. Should be what you get out of the box. I see a
> public int insertLayer(layerObj layer, int index)
Which is what I have...
> Once again I forgot that there are no optional method arguments for
> Java. Sorry. In the Python mapscript, this method's signature is
> insertLayer(layer, index=-1)
> and we can omit the index, it defaults to -1, or the end of the
> layers list.
Had I the time to rewrite this app in Python, I would :-)
> In your case, insert a layer at the end with
> li = map.insertLayer(layer, -1)
OK - I was using
map.insertLayer(layer, map.getNumlayers())
naively assuming it would insert at the appropriate index. Thanks.
> Which version of SWIG are you using?
SWIG 1.3.24
Mapserver 4.4.2
Things seem to be working now...I'm letting a stress test run so
we'll see how that works. (It's just curl in a while loop, but it
does the trick.)
Thanks,
--Rick.
