Resampling rasters from unprojected WMS sources ?
Lars V. Nielsen (HVM)
LVN at HVM.DK
Tue May 31 03:52:16 EDT 2005
Hi Ed,
Posting the complete MAP file would be too much, and I thought the general
issue whether MS can reproject wms/rasters or not wouldn't need specific
examples.
But in any case, here is a relevant excerpt:
MAP myMAP
RESOLUTION 96
STATUS ON
UNITS METERS
SIZE 600 480
EXTENT 363842 6027893 863744 6427815
PROJECTION
"init=EPSG:25832"
END
# the lat-long WGS84 only WMS service
LAYER
NAME GoogleMaps
TYPE RASTER
STATUS ON
CONNECTIONTYPE WMS
CONNECTION
"http://www.gispro.dk/googlemaps_wms.php?service=wms&version=1.1.1&request=g
etmap&layers=sat_auto&format=image/jpeg"
PROJECTION
"init=EPSG:4326"
END
END
# other vector layers natively in EPSG:25832, e.g.:
LAYER
NAME "myVectorLayer"
PROJECTION
"init=EPSG:25832"
END
Type LINE
CONNECTIONTYPE OGR
CONNECTION ".../myTable.TAB"
STATUS ON
CLASS
COLOR 0 0 255
TEMPLATE void
END
TOLERANCE 10
END
END
I've uploaded the experienced visual appearence of the same front vector
layer with each background layer :
- with satellite imagery: http://www.gis.hvm.dk/test/ms_sat_back.jpg (with
the flattened appearence)
- with grey backdrop: http://www.gis.hvm.dk/test/ms_grey_back.png
- as seen in MapInfo Pro (distorts the vector to fit the raster):
http://www.gis.hvm.dk/test/mi_sat_back.jpg
I'm using MapScript 4.5 ($Revision: 1.223 $ $Date: 2005/01/04 22:55:27 $) in
Php 4.3.7 on W2K.
Best regards / Med venlig hilsen
Lars V. Nielsen
Hvenegaard & Meklenborg
Rugaardsvej 55, DK-5000 Odense C
Denmark
http://www.hvm.dk
----- Original Message -----
To: "Lars V. Nielsen (HVM)" <LVN at HVM.DK>; <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Friday, May 27, 2005 8:36 PM
Subject: RE: [UMN_MAPSERVER-USERS] Resampling rasters from unprojected WMS
sources ?
Lars -
It sounds like the right approach; could you post the MAP file if
possible? Thanks.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Lars V. Nielsen (HVM)
Sent: Friday, May 27, 2005 9:14 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Resampling rasters from unprojected WMS
sources ?
I'm rendering a map in a UTM projection, but want to add a satellite
image wms service that only delivers images in lat/long wgs84.
No problem, I set the wms layer projection to epsg:4326, while my map
(and other layers) use projection epsg:25832. And it works, or almost
The sat image is distorted - "flattened" - so the vector line work
layers on top of it exceeds the country coast line north and south. And
quite significantly so.
Shouldn't the raster re-projection algoritms in Mapserver take care of
such distortions, or is mixing projected and unprojected coordinate
systems
(still) a no-no ?
Lars V. Nielsen
Denmark
http://www.hvm.dk
