Pseudo-Dynamic Layer
Steve Lime
steve.lime at DNR.STATE.MN.US
Thu Nov 3 01:13:58 EST 2005
David: You can do this a bit easier, same idea but a more streamlined syntax:
Your URL would contain stuff like this (instead of the nasty map_... syntax):
...&group1=16,25,77,11,12,13,14,15&group2=1,2,3&...
and in your mapfile your expressions would look like:
EXPRESSION ('[COUN]' in '%group1%')
EXPRESSION ('[COUN]' in '%group2%')
basically you're just passing part of the expression.
>>> "Fawcett, David" <David.Fawcett at STATE.MN.US> 11/02/05 8:57 PM >>>
OK, so I have the solution to my own problem...
I want to classify county polygons based on data that is not in the county shapefile. Outside of MapServer, I query the database and derive class values (1-5) for each county. I then build a URL that I use to build class expressions, the expression for each class contains the county ID numbers that should be assigned to that class.
http://127.0.0.1:8080/cgi-bin/mapserv?map=/opt/fgs/www/htdocs/maps/testmap/testmap.map&mode=map&map_basemap_class_0_expression=('[COUN]'+IN+('16,25,77,11,12,13,14,15'))&map_basemap_class_1_expression=('[COUN]'+IN+('2,4,6,7,8,9,10'))&map_basemap_class_2_expression=('[COUN]'+IN+('87,86,85,84,83,82,81,80,79,78,77,76,75,74'))&map_basemap_class_3_expression=('[COUN]'+IN+('70,71'))
The mapfile layer looks like:
LAYER
NAME basemap
STATUS DEFAULT
TYPE POLYGON
DATA 'bdry_counpy2'
CLASSITEM "COUN"
CLASS
NAME "zero"
EXPRESSION /0/
OUTLINECOLOR 153 153 153
#COLOR 196 193 161
COLOR 255 204 205
END
CLASS
NAME "one"
EXPRESSION /0/
OUTLINECOLOR 255 153 153
#COLOR 196 193 161
COLOR 255 153 255
END
CLASS
NAME "two"
EXPRESSION /0/
#COLOR 196 193 161
COLOR 255 102 255
END
CLASS
NAME "three"
EXPRESSION /0/
#COLOR 196 193 161
COLOR 255 0 255
END
CLASS
NAME "four"
#COLOR 196 193 161
COLOR 255 255 255
END
END #end layer
I guess that it is kind of 'reverse classification'. Kludgy as heck, but it gets me the map that I want for the demo...
David.
-----Original Message-----
Sent: Wed 11/2/2005 5:13 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Pseudo-Dynamic Layer
In MapServer CGI, is it possible to use URL parameters to pass polyID:value pairs to generate a map that classifies the indicated polys by the value passed? The geometry is stored in a shapefile.
Obviously, one can get halfway there using Itemnquery to highlight polys.
It is the age-old issue of having the geometry in a shapefile and wanting to classify poly by data stored somewhere else.
I realize that this is pretty easily accomplished with a spatial database back-end, and that it is probably a pretty simple mapscript app, I am just trying to figure out if it can be done using CGI and URL values.
Thanks,
David.
