Tab, Shp, Shptree, PostGIS performance
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Thu Nov 3 05:39:04 EST 2005
how do you reference your shapefile in your MAP file?
Maybe your data statement contains myshp.shp and then the qix file won't be found (it looks for myshp.shp.qix then).
Your data statement should look like:
DATA "myshp"
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Erki Saluveer <erki.saluveer at REGIO.EE> 3-11-2005 11:22 >>>
Hi
I've been using Minnesota Mapserver for a while with a big success. Though I
haven't understood completely which file formats to read fits best for
Mapserver.
Biggest mystery is shape file. It should be the fastest file format to read,
but it's been the slowest in all my tests.
Like one test I made with Mapinfo TAB, ESRI shape, PostGIS database table
and shptree file.
I had at first one MapInfo dataset (33 Mb). To get shape file I translated
it with MapInfo's Universal Translator. From shape file I made qix file with
shptree in depth 8 and using shp2pgsql I created database entry file (I also
indexed postgis table)
Then I put together 4 different map files to read these. Test was made with
single and concurrent queries (500 queries for each map file).
The results are as follows:
File Type
Time per request
Time per concurrent request
TAB
78
30
SHP
835
579
SHP with qix
822
580
19
* Times are in milliseconds
Why is shape so slow?!? I appreciate any help to find answer to this
question.
Sincerely,
Erki Saluveer
