Tab, Shp, Shptree, PostGIS performance
Ed McNierney
ed at TOPOZONE.COM
Thu Nov 3 07:08:03 EST 2005
Erki -
Your test results are SLOWER in one case with the QIX file, and faster
in the other. Both are by such small amounts they don't tell anything.
Try deleting your QIX file and re-running the tests to see if it
matters.
Also, you need to give us some more information about the type of
request you're testing. Are you using a request that causes most of the
data to be drawn on the map, or only a small portion of the data? Can
you describe the shapes of the individual data objects? That is, are
they roads, state outlines, etc.?
The results are very dependent on the type of data and the type of
request, which is why it is hard to compare two different user
situations.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Erki Saluveer
Sent: Thursday, November 03, 2005 5:59 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Tab, Shp, Shptree, PostGIS
performance
My shptree files are:
Myshp.dbf
Myshp.prj
Myshp.qix
Myshp.shp
Myshp.shx
Anyways it does read qix file, because test results are a bit faster
with qix file, but the difference is very-very small.
What else could be the reason?
I've been looking Mapserver user-list archives and haven't found anyone
making this kind of tests. Maybe someone has done and could put his/her
results. It would be nice to compare.
Erki Saluveer
Behalf Of Bart van den Eijnden
Sent: Thursday, November 03, 2005 12:39 PM
performance
how do you reference your shapefile in your MAP file?
Maybe your data statement contains myshp.shp and then the qix file won't
be found (it looks for myshp.shp.qix then).
Your data statement should look like:
DATA "myshp"
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Erki Saluveer <erki.saluveer at REGIO.EE> 3-11-2005 11:22 >>>
Hi
I've been using Minnesota Mapserver for a while with a big success.
Though I haven't understood completely which file formats to read fits
best for Mapserver.
Biggest mystery is shape file. It should be the fastest file format to
read, but it's been the slowest in all my tests.
Like one test I made with Mapinfo TAB, ESRI shape, PostGIS database
table and shptree file.
I had at first one MapInfo dataset (33 Mb). To get shape file I
translated it with MapInfo's Universal Translator. From shape file I
made qix file with shptree in depth 8 and using shp2pgsql I created
database entry file (I also indexed postgis table)
Then I put together 4 different map files to read these. Test was made
with single and concurrent queries (500 queries for each map file).
The results are as follows:
File Type
Time per request
Time per concurrent request
TAB
78
30
SHP
835
579
SHP with qix
822
580
19
* Times are in milliseconds
Why is shape so slow?!? I appreciate any help to find answer to this
question.
Sincerely,
Erki Saluveer
