WFS on 4.4.1 works and not on 4.6.0
Bart van den Eijnden
bartvde at XS4ALL.NL
Thu Nov 3 13:33:58 EST 2005
What GetFeature request are you trying? Can you post it?
Also, in 4.6 the name of the geometry attribute (in the PropertyName
part of your request) is now important and should be MSGEOMETRY if I
recall correctly. The name was ignored in version 4.4.
Best regards,
Bart
Simpson wrote:
>That fixed the describefeaturetype, but getfeatures is still not returning
>any features.
>Below is all that is returned. The BBOX is in the projection of the layer?
>Thanks,
>Drew.
><?xml version='1.0' encoding="ISO-8859-1" ?>
><wfs:FeatureCollection
> xmlns:myns="http://www.ttt.org/myns"
> xmlns:wfs="http://www.opengis.net/wfs"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/wfs
>http://ogc.dmsolutions.ca/wfs/1.0.0/WFS-basic.xsd
>https://xxxx/xxx&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatu
>reType&TYPENAME=xxxx&OUTPUTFORMAT=XMLSCHEMA">
> <gml:boundedBy>
> <gml:Box srsName="EPSG:32615">
> <gml:coordinates>806291.512569,3346809.680220
>809504.014362,3348828.847769</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
></wfs:FeatureCollection>
>-----Original Message-----
>From: Bart van den Eijnden [mailto:BEN at Syncera-ITSolutions.NL]
>Sent: Thursday, November 03, 2005 10:35 AM
>To: asimpson at I-55.COM; MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] WFS on 4.4.1 works and not on 4.6.0
>Also try adding
>gml_include_items "all"
>to your LAYER"s METADATA section.
>Bart
>Syncera IT Solutions
>Postbus 270
>2600 AG DELFT
>tel.nr.: 015-7512436
>email: BEN at Syncera-ITSolutions.nl
>>>>Simpson <asimpson at I-55.COM> 3-11-2005 17:33:34 >>>
>Is there any reason WFS getfeatures and describefeaturetype works fine in
>4.4.1, but in 4.6.0 no features are returned from getfeatures, and the
>describefeaturetype only describes the geometry. The getcapabilities seems
>to work ok.
>I can see MS making the SQL calls in the PostGIS DB (4.6.0 is much different
>than 4.4.1), and it looks as if its getting the four geometries ok ( I run
>the SQL it issued and get the four rows back )
>The only place I see it getting attribute data it issues:
>DECLARE mycursor2 BINARY CURSOR FOR SELECT
>ection(force_2d(the_geom)),'NDR') from xxxx WHERE name = 0
>There isn't a row with name = 0 in the table, so it will not get any rows,
>but maybe all its after is data types?
>The 4.4.1 version gets the geometry and oid, then loops through each oid
>getting attribute, geom data:
>ection(force_2d(the_geom)),'NDR') from xxxx WHERE OID = 13350367
>In case its useful, an almost identical map file works correctly, the table
>has different columns and the SRID is 4326 not 32615.
>Thanks for any suggestions,
>Drew.
>MapServer version 4.4.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
>SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=POSTGIS
>INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
>MapServer version 4.6.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG
>SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=THREADS INPUT=TIFF
>INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
># Start of map file
>NAME DEMO
>STATUS ON
>SIZE 600 600
>EXTENT 806141.887843 3346695.719558 810886.158231 3350349.755389
>UNITS meters
>SHAPEPATH "data"
>IMAGECOLOR 255 255 255
>DEBUG ON
># you may need to change this to match your MapServer build
>IMAGETYPE png_rgb
># Projection definition, consult the PROJ.4 documentation for parameter
>discussion
>PROJECTION
> "init=epsg:32615"
>END
># PROJECTION
>OUTPUTFORMAT
> NAME png_rgb
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE RGB
> EXTENSION "png"
>END
># Start of web interface definition (including WMS enabling metadata)
>WEB
> IMAGEPATH "/var/www/ssl/html/scratch/"
> IMAGEURL "scratch/"
> METADATA
> "wfs_title" "WFS for xxx"
> "wfs_onlineresource" "https://www.xxx.xxx..."
> "wfs_srs" "EPSG:32615"
> "ows_schemas_location" "http://ogc.dmsolutions.ca"
> END
>END
># Start of symbol definitions (we're only using a few)
>SYMBOL
> NAME 'circle'
> TYPE ELLIPSE
> POINTS 1 1 END
> FILLED TRUE
>END
># Start of layer definitions
>LAYER
> NAME "xxxx"
> #STATUS OFF
> STATUS ON
> TYPE POLYGON
> DUMP TRUE
> CONNECTIONTYPE postgis
> CONNECTION "user=xxx password=xxx dbname=xxx host=xxx port=5432"
> DATA "the_geom from xxxx"
> #TEMPLATE "/var/www/ssl/html/xxx"
> #TOLERANCE 10
> #TOLERANCEUNITS meters
> PROJECTION
> "init=epsg:32615"
> END
> METADATA
> "wfs_title" "xxxx"
> "wfs_abstract" "xxxx"
> "wfs_keywordlist" "xxxx"
> END
>END
>END
>TABLE DEFINITION
> Column | Type | Modifiers
> name | character(24) | not null
> description | character varying(256) |
> the_geom | geometry |
> an_int | integer |
> comments | character varying |
>Indexes:
> "xxxx_pkey" primary key, btree (name)
>Check constraints:
> "$1" CHECK (srid(the_geom) = 32615)
> "$2" CHECK (geometrytype(the_geom) = 'MULTIPOLYGON'::text OR the_geom IS
>NULL)
