Merge several layers into a single multi-layer GetMap request
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Thu Nov 3 14:20:14 EST 2005
Yes Please do so and I will update the code.
Later,
J. Parapar wrote:
> Hi Assefa, thanks for your time.
> Looking at mapwmslayer.c, at the lines following those, it seems that
> the parameters which are allowed to be different between the two
> requests are LAYERS, QUERY_LAYERS and STYLES. The SLD_BODY parameter
> is different in each request so the layers are not merged.
> May I post a bug on this in http://mapserver.gis.umn.edu/bugs/?
> Thanks again,
> Jorge
> 2005/11/3, Yewondwossen Assefa <assefa at dmsolutions.ca>:
>>Hi There,
>> I am nopt sure why would this happen. Cheking the code, the criteria
>>for merging is the following (mapwmlalayer.c around line 927) :
>> if (!bForceSeparateRequest &&
>> lastconnectiontype == MS_WMS &&
>> psLastWMSParams != NULL &&
>> sThisWMSParams.numparams == psLastWMSParams->numparams &&
>> strcmp(sThisWMSParams.onlineresource,
>> psLastWMSParams->onlineresource) == 0)
>> which translates into :
>> - no metadata set force_separate_request
>> - number of parameters are the same between 2 requests
>>(parameters being all the manadatory and non manadory request parameters)
>> - the onlineresource should be the same.
>> Adding a wmss_sld_body would only end up adding one paramater. If all
>>your consececutive layers follow these criterias, It shoudl merge.
>> Thinking about It and reading the doc, I am not sure why the number of
>>parameters is added into the test.
>>Later,
>>J. Parapar wrote:
>>>Hi all
>>>We have several wms layers with the same wms server in our mapfile
>>>client and MapServer is making one GetMap request for each of the
>>>layers. All the layers have the parameter wms_sld_body set to AUTO. In
>>>some tests with layers without SLD MapServer do merges several layers
>>>into a single multi-layer GetMap request. Does this optimization only
>>>works with non SLD layers?
>>>Thanks in advance,
>>>Jorge
>>Assefa Yewondwossen
>>Software Analyst
>>Email: assefa at dmsolutions.ca
>>http://www.dmsolutions.ca/
>>Phone: (613) 565-5056 (ext 14)
>>Fax: (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
