getfeatureinfo in a wms
Bart van den Eijnden bartvde at XS4ALL.NL
Fri Nov 4 11:01:45 EST 2005
Mapserver does not cascade WMS GetFeatureInfo, it will not ask the
remote server for feature info. This is because the response is poorly
defined in the WMS spec.
So you would need to build the GetFeatureInfo URL to the remote server
yourself in the client and do the request and present the results. If
you are using Mapscript there is a function in the API which builds up
the GetFeatureInfo URL for you.
Best regards,
Bart
Lluís Garcia i Mestres wrote:
> Hi list,
> I'm trying to implement a new wms layer from the following server:
> http://ovc.catastro.meh.es/Cartografia/WMS/ServidorWMS.aspx?
> I can display it but I can't figure out how to get the getfeatureinfo
> in an html. My viewer says that there aren´t query point. Anyone can
> help to solve this?
> My layer parameters are:
> LAYER
>     NAME cadastre2
>     TYPE RASTER
>     GROUP cadastre2
>     STATUS ON
>     TEMPLATE
>     "c:\ms4w\Apache\htdocs\mapserver\dades\catalunya\templates\query_buit.html"
>     CONNECTIONTYPE WMS
>     CONNECTION
>     "http://ovc.catastro.meh.es/Cartografia/WMS/ServidorWMS.aspx?"
>     METADATA
>         "wms_name" "Cartografía"
>         "wms_request" "GetFeatureInfo"
>         "wms_title" "Catastro"
>         "wms_server_version" "1.1.0"
>         "wms_service" "WMS"
>         "wms_srs" "EPSG:23031"
>         "wms_layers" "Cartografía"
>         "wms_format" "image/png"
>         "wms_query_layers" "Cartografía"
>         "wms_info_format" "text/html"
>         "wms_transparent" "TRUE"
>         "wms_height" "400"
>         "wms_width" "500"
>         "wms_x" ""
>         "wms_y" ""
>         "wms_exception" "INIMAGE"
>         LLEGENDA_GRUP "Fons"
>         LLEGENDA_NOM "Cadastre query"
>         END
>     PROJECTION
>         "proj=utm"
>         "ellps=GRS80"
>         "zone=31"
>         "north"
>         "no_defs"
>     END
> END
> Thanks
> lluis
