problems with running phtml srcipts
Gambin Dejan Dejan.Gambin at PULA.HR
Mon Nov 7 04:59:20 EST 2005
I still can't get ms4w to run my phtml file as php. It must be some stupid mistake I am doing but I can't find the reason. If I try loading a simplest .phtml file on localhost I get "http 404 - file not found" error. the same file with .php extension works fine.
Does anyone know what can be the problem and can it be related to running apache on port 8080 while at the same time running IIS on port 80 (the problem is I shouldn't stop the IIS if not necessary!)
regards, dejan
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Blaise Picinbono
> Sent: Friday, November 04, 2005 3:49 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] problems with running phtml srcipts
> Sorry, as I told you, I don't know anything about IIS, so I
> can't tell if it
> has to be restarted or not. You'd better run gnu/linux, but
> that's only my
> point of view ;-)
> It's strange that your phtml page is blank. Did you check the
> source code of
> the page ? What does it tell ?
> Blaise
> Le Vendredi 4 Novembre 2005 15:42, Gambin Dejan a écrit :
> > Apache yes, IIS no..why should IIS be restarted?
> > dejan
> Blaise Picinbono
> > > Sent: Friday, November 04, 2005 3:40 PM
> > > srcipts
> > > Le Vendredi 4 Novembre 2005 15:11, Gambin Dejan a écrit :
> > > > Hi,
> > > > I have installed mapserver 4.6 by the ms4w package on my
> > > Windows 2000
> > > > machine. The problem is I have a running IIS, and I simply
> > > configured
> > > > the Apache to listen on port 8080 to run together with IIS.
> > > Everything
> > > > seems ok but I can't run phtml scripts as php files. I have the
> > > > following in my httpd.conf:
> > > > AddType application/x-httpd-php .phtml .php
> > > > Action  application/x-httpd-php /cgi-bin/php.exe
> > > > I can run normally the php scripts but I get an empty page
> > > when trying
> > > > to open any phtml file. I have also tried with
> configuring php as
> > > > apache module but the result is the same. ms4w is using
> > > Apache 2.0.54
> > > > and php 4.3.11.
> > > > Any help?
> > > > regards, dejan
> > > Hi,
> > > I don't know much about IIS. Your Apache config file
> seems ok. Did
> > > you restart the Apache server so that it read again the
> config file
> > > ? Did you restart IIS ?
> > > Blaise
