problems with running phtml srcipts
Gambin Dejan
Dejan.Gambin at PULA.HR
Mon Nov 7 05:43:36 EST 2005
I solved the problem, it was firewall blocking the phtml files..
thanks anyway
dejan
> -----Original Message-----
> From: Gambin Dejan
> Sent: Monday, November 07, 2005 10:59 AM
> To: 'bpicinbono at WORLDONLINE.FR'
> Cc: 'MAPSERVER-USERS at LISTS.UMN.EDU'
> Subject: RE: [UMN_MAPSERVER-USERS] problems with running phtml srcipts
> Hi,
> I still can't get ms4w to run my phtml file as php. It must
> be some stupid mistake I am doing but I can't find the
> reason. If I try loading a simplest .phtml file on localhost
> I get "http 404 - file not found" error. the same file with
> .php extension works fine.
> Does anyone know what can be the problem and can it be
> related to running apache on port 8080 while at the same time
> running IIS on port 80 (the problem is I shouldn't stop the
> IIS if not necessary!)
> regards, dejan
> > From: UMN MapServer Users List
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Blaise Picinbono
> > Sent: Friday, November 04, 2005 3:49 PM
> > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > Subject: Re: [UMN_MAPSERVER-USERS] problems with running
> phtml srcipts
> > Sorry, as I told you, I don't know anything about IIS, so I
> > can't tell if it
> > has to be restarted or not. You'd better run gnu/linux, but
> > that's only my
> > point of view ;-)
> > It's strange that your phtml page is blank. Did you check the
> > source code of
> > the page ? What does it tell ?
> > Blaise
> > Le Vendredi 4 Novembre 2005 15:42, Gambin Dejan a écrit :
> > > Apache yes, IIS no..why should IIS be restarted?
> > > dejan
> > Blaise Picinbono
> > > > Sent: Friday, November 04, 2005 3:40 PM
> > > > Subject: Re: [UMN_MAPSERVER-USERS] problems with running phtml
> > > > srcipts
> > > > Le Vendredi 4 Novembre 2005 15:11, Gambin Dejan a écrit :
> > > > > Hi,
> > > > > I have installed mapserver 4.6 by the ms4w package on my
> > > > Windows 2000
> > > > > machine. The problem is I have a running IIS, and I simply
> > > > configured
> > > > > the Apache to listen on port 8080 to run together with IIS.
> > > > Everything
> > > > > seems ok but I can't run phtml scripts as php files.
> I have the
> > > > > following in my httpd.conf:
> > > > > AddType application/x-httpd-php .phtml .php
> > > > > Action application/x-httpd-php /cgi-bin/php.exe
> > > > > I can run normally the php scripts but I get an empty page
> > > > when trying
> > > > > to open any phtml file. I have also tried with
> > configuring php as
> > > > > apache module but the result is the same. ms4w is using
> > > > Apache 2.0.54
> > > > > and php 4.3.11.
> > > > > Any help?
> > > > > regards, dejan
> > > > Hi,
> > > > I don't know much about IIS. Your Apache config file
> > seems ok. Did
> > > > you restart the Apache server so that it read again the
> > config file
> > > > ? Did you restart IIS ?
> > > > Blaise
