Box on reference map
Stephen Davies
sdc at SDC.COM.AU
Mon Nov 7 19:14:46 EST 2005
G'day.
I am building an application based on the javascript dbox tutorial.
My data is all stored in PostGIS as lat/longs (SRID 4283) and I am
projecting this to the main map. (I have tried several different projections
but have currently settled on eqc.)
My reference map image was created by taking a snapshot of the main map and
reducing it to 120x120.
I have amended mapserv.js to handle southern hemisphere data.
If I do not project the data (map projection=init=epsg:4283), everything
seems to work fine and in particular, the current box of interest displays
on the reference map.
However, when I do project the data (with map projection laea, merc or eqc
and changing units from DD to metres) the box of interest stops displaying
even though all other operations - including clicking on the reference map -
continue to work.
Here is my map file.
MAP
NAME bp1
EXTENT 112.0 -44.0 154.0 -9.0
PROJECTION
# "init=epsg:4283"
# "proj=laea"
# "proj=merc"
"proj=eqc"
"lon_0=138e"
END
SIZE 600 600
UNITS METERS
# UNITS DD
imagetype png
imagecolor 255 255 255
web
template /usr/local/apache2/htdocs/benparts/templates/test1.html
imagepath "/usr/local/apache2/htdocs/tmp/"
imageurl "/tmp/"
end
LAYER
CONNECTIONTYPE postgis
NAME "layer1"
DATA "the_geom from geog5"
CONNECTION "user=scldad dbname=benparts"
STATUS default
TYPE POLYGON
PROJECTION
"init=epsg:4283"
END
CLASS
NAME "Oz"
STYLE
COLOR 168 255 214
OUTLINECOLOR 0 0 0
END
END
END
# Start of reference map
REFERENCE
IMAGE /usr/local/apache2/htdocs/benparts/refmaps/oz.png
SIZE 120 120
STATUS ON
MINBOXSIZE 5
MAXBOXSIZE 100
COLOR 0 255 0
OUTLINECOLOR 0 0 0
MARKERSIZE 8
MARKER 'star'
END
# Start of scalebar
SCALEBAR
IMAGECOLOR 0 0 0
LABEL
COLOR 255 255 255
SIZE TINY
END
STYLE 1
SIZE 200 2
COLOR 255 255 255
UNITS KILOMETERS
INTERVALS 2
TRANSPARENT TRUE
STATUS ON
END
END
What have I missed?
Cheers and thanks,
Stephen
