DWithin question (distance defintion in Mapserver)
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Tue Nov 8 10:00:35 EST 2005
Hi There,
The DWithin is transformed into a querybyshape with a tolernace set
using the distance parameter of the request.
A querybyshape is working like this from what I can see in the code :
- shape 1 is your query shape
- shape 2 : is the shape of the layer
1) shape1 is point, shape 2 is either point/line/polygon
- shape 2 is a point : msDistancePointToPoint (distance between the
2 points)
- shape 2 is a line : msDistancePointToSegment (distance from the
nearest point on the segment. Each segment of the line is considered.)
- shape 2 is a polygon : msDistancePointToSegment
2) shape 1 is a line
* shape 2 is a point : msDistancePointToPoint
* shape 2 is a line : check if they intersect and then
msDistanceSegmentToSegment (nearesr points on the segments)
* shape 2 is a polygon : check if contains and then check for
intersecton and then msDistanceSegmentToSegment
3) shape 1 is a polygon :
* shape 2 is a point : msDistancePointToShape
* shape 2 is a line : contains and then interects and then
* shape 2 is a polygon : contains and then interects and then
I think the way the query works fits the definition of distannce form
OGC.
Later,
Bart van den Eijnden wrote:
> Hi list,
> in my application I am trying to look up which polygon contains a certain point. Since Mapserver WFS does not support Contains, I currently use DWithin.
> How does the DWithin internally work? I now have a situation in which the wrong polygon is picked, which makes me suspect it works with calculating the distance from the polygon's centroid, and not the smallest distance towards one of the polygons borders. What does the OGC spec say about this? If I read the OGC Simple Features for SQL I read a different definition for distance:
> Distance(anotherGeometry:Geometry):Double*Returns the shortest distance between any two points in
> the two geometries as calculated in the spatial reference system of this Geometry.
> Btw, I never got an intersect of a point with a polygon layer to work, which was my first plan to solve this.
> Any help appreciated. Thanks in advance.
> Best regards,
> Bart
> Syncera IT Solutions
> Postbus 270
> 2600 AG DELFT
> tel.nr.: 015-7512436
> email: BEN at Syncera-ITSolutions.nl
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
