.map within a .map
Tamas Szekeres
szekeres.tamas at FREEMAIL.HU
Tue Nov 8 19:03:02 EST 2005
And it is also possible to utilize mapscript to implement merging the
layers from different map files into a single map. The global map settings
(eg. shapepath, fontset, symbolset) should be collated during the merge.
Best Regards,
Tamas Szekeres
On Tue, 8 Nov 2005 10:00:18 -0500, Frank Warmerdam <warmerdam at POBOX.COM>
wrote:
>On 11/8/05, Oliver Ishmael <oliver_ishmael at hotmail.com> wrote:
>> Hi all,
>> Is it possible to call a nested .map file within a mapfile.
>> For example, i am developing a mapserver for work and have some of the
data
>> at home, but not the raster data for example. To enable me to easily
run and
>> edit the mapfile from home, it would be useful if some of this data
could be
>> called in a separate mapfile, (which i could comment out as necessary).
>> What is the syntax for calling a .map file from within a .map file.
>Olly,
>You might want to talk to Tamas about the work he did
>to allow another .map to be used as a raster layer. There
>is some description in:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1445
>This isn't incorporated into the mainline MapServer at this point
>but it might be if we felt there was a strong enough desire for it.
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
