Join between Postgis table and Postgresql table
Frans Knibbe
frans at GEODAN.NL
Wed Nov 9 04:53:37 EST 2005
Hello Carlo,
If your data do not change much you could join the two tables in
postgreSQL to make a new table which can be used by MapServer. This you
will probably have better performance as well.
Regards,
Frans
Carlo Calvino wrote:
>Hello all of you,
>I built a spatial database with PostgreSql/PostGis, and imported a
>shapefile (cities.shp) inside it. So I have a postgresql database with 2
>tables, one for the geographic data and the other for alphanumeric data.
>I was able to publish the vector data by MapServer, and I was also able to
>query it correctly. But...what about querying the vector layer using
>information from the second table? I need joining the two tables. As far
>as I know, it is only possible a join between Postgis and a dbf file, not
>a DBMS. So there are any suggestions?
