php mapscript with postgresql 8.1
Stéphane RIFF
stephane.riff at CERENE.FR
Wed Nov 9 08:12:46 EST 2005
I don't think there were an old link libpq.so.3 before compile mapserver.
But when i try ln -s lipq.so.3 libpq.so.4 i doesn't work, my libpq.so.4
is in /usr/local/pgsql/lib/ does it matter ?
Oliver Lichte wrote:
>Hallo Steff,
>it could be there is a link which refers to nothing named libpq.so.3 on your
>system. If it exists you must remove it and repeat compilation. As a really
>straight-forward work-around you could create an symbolic link 'libpq.so.3'
>refering to libpq.so.4 by
>ln -s libpq.so.3 libpq.so.4
>within the according directory (/usr/lib I guess). In this case you must not
>compile again, but there is no guarantee that it works.
>Regards,
>Oliver
>Am Mittwoch, 9. November 2005 12:02 schrieb Stéphane RIFF:
>>Trying to run PHPMapscript 4.6.1 against posgresql 8.1, postgis 1.0.4,
>>php 4.3.9
>>All compiles fine without error. But when i launch the application in
>>the browser i get those errors :
>>dl(): Unable to load dynamic library
>>'/usr/local/lib/php/ext/php_mapscript.so' - libpq.so.3: cannot open
>>shared object file: No such file or directory
>>*Fatal error*: Call to undefined function: ms_newmapobj() in */var/www/html
>>*But with postgresql 8.1 the libpq.so.3 doesn't exist it's libpq.so.4
>>So does anyone get this to work, or maybe postgresql 8 is not supported
>>by mapserver now???
>>Any workaround is welcome
>>Thanks
>>Steff
