join photos and bases
Joana Nicolini Cunha
joanancunha at UOL.COM.BR
Thu Nov 10 09:13:30 EST 2005
Yes, I want to overlay the raster with vector. But I would like to pick up
the image from google earth or google map.
thanks,
Joana
----- Original Message -----
From: "Stephen Woodbridge" <woodbri at SWOODBRIDGE.COM>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, November 08, 2005 6:37 PM
Subject: Re: [UMN_MAPSERVER-USERS] join photos and bases
> Or are you looking to display raster data and overlay that with vector
> data where these might be in different projections? Which is easier to do
> in mapserver.
> -Steve W.
> Steve Lime wrote:
>> Can you be more specific with regards to the process you are
>> envisioning? It sounds like you want to select some vector feature
>> and use that so select a photograph. That is possible, but is that
>> what you are asking.
>> Steve
>>>>> joanancunha <joanancunha at UOL.COM.BR> 11/08/05 11:00 AM >>>
>> Hi,
>> I need to Know how I can join a satellite photograph, with respect
>> coordenates, and a vectorial map or base, using mapserver. Is there a
>> specific command?
>> thank you,
>> Joana
