shp2img segfaults on sde connection
Hancock, Eric
Eric.Hancock at DEP.STATE.FL.US
Thu Nov 10 10:44:02 EST 2005
Hello all,
I have a mapfile that (and could possibly be configured incorrectly) when
trying to generated an image from makes shp2img segfault at msFreeMap(). The
image gets generated fine, but shp2img segfaults. When running mapserv as a
cgi this causes mapserv to never return the image to the client. Here's my
mapfile:
MAP
IMAGETYPE PNG
EXTENT 500000 600000 600000 700000
SIZE 400 300
IMAGECOLOR 255 255 255
DEBUG ON
PROJECTION
"datum=NAD83"
"proj=aea"
"ellps=GRS80"
"a=6378137"
"rf=298.257222101"
"lat_0=24"
"lon_0=-84"
"lat_1=24"
"lat_2=31.5"
"x_0=400000"
"y_0=0"
"units=m"
END
# Start of LAYER DEFINITIONS
LAYER # COUNTYSHORE_AREAS polygon layer begins here
NAME county
CONNECTION "gistest.dep.state.fl.us,port:5151,sde,user,password"
CONNECTIONTYPE SDE
DATA "BASE.COUNTYSHORE_AREAS,SHAPE,SDE.DEFAULT"
TEMPLATE "/tmp/dummy.tmp"
STATUS DEFAULT
TYPE POLYGON
DEBUG ON
# PROJECTION
# "datum=NAD83"
# "proj=aea"
# "ellps=GRS80"
# "a=6378137"
# "rf=298.257222101"
# "lat_0=24"
# "lon_0=-84"
# "lat_1=24"
# "lat_2=31.5"
# "x_0=400000"
# "y_0=0"
# "units=m"
# Alternatively, you can specify an EPSG code.
#"init=epsg:102003"
# END
CLASS
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END # States polygon layer ends here
# End of LAYER DEFINITIONS -------------------------------
#Start of WEB Object
WEB
IMAGEPATH "/tmp/"
# IMAGEURL "http://199.73.196.65/"
LOG "/tmp/mapservererror.log"
END
END # end of map file/object
--------------shp2img------------------
[oracle at localhost]#./shp2img -m test.map -o test.png
Segmentation fault (core dumped)
-------gdb log-----------------
Starting program: /home/oracle/mapserver-4.6.1/shp2img -m test.map -o
[Thread debugging using libthread_db enabled]
[New Thread -1218568064 (LWP 28077)]
[Switching to Thread -1218568064 (LWP 28077)]
Breakpoint 1, msFreeMap (map=0x886a198) at mapobject.c:145
145 if(!map) return;
(gdb) next
142 void msFreeMap(mapObj *map) {
(gdb) next
(gdb) next
146 msCloseConnections(map);
(gdb) next
Program received signal SIGSEGV, Segmentation fault.
0x00cd6bb2 in pthread_join () from /lib/tls/libpthread.so.0
Does anyone know what I'm doing wrong, or is something wrong with my compile?
Thanks,
Eric hancock
Florida DEP
BIS/GIS
