Can't install MapServer
Alejandro Mejia Evertsz
amejia at GUA.NET
Fri Nov 11 12:06:53 EST 2005
Thank you very much Manfred!
Now ./configure ends fine.
Danke!
-----Original Message-----
From: Manfred Meier [mailto:m.meier at spiekermann.de]
Sent: Viernes, 11 de Noviembre de 2005 10:47 a.m.
To: Alejandro Mejia Evertsz
Subject: Re: [UMN_MAPSERVER-USERS] Can't install MapServer
Hello,
I tried it on my SuSE and there was the same problem:
--with-gd=/usr/local/include
didn't do it, but
is ok. Perhaps it looks then for include and lib.
hope, that helps
Manfred
Alejandro Mejia Evertsz schrieb:
> Thanks Gavin and Stephen.
> I forgot to mention I'm running a FreeBSD 5.4 box.
> I followed your advises like this:
> I did:
> # whereis gd
> gd: /usr/ports/graphics/gd
> But didn't seem logical to me, cause that location is where you
> install the port from.
> Anyway, I tried:
> #./configure --with-gd=/usr/ports/graphics/gd
> Got the same error.
> I searched the files it says and got this locations:
> # find / -name libgd.so
> /usr/local/lib/libgd.so
> # find / -name libgd.a
> /usr/local/lib/libgd.a
> # find / -name gd.h
> /usr/local/include/php/ext/gd/libgd/gd.h
> /usr/local/include/gd.h
> /usr/ports/graphics/graphviz/work/graphviz-2.2/gd/gd.h
> /usr/ports/print/dvipsk-tetex/work/tetex-src-3.0/libs/gd/gd.h
> /usr/ports/print/teTeX-base/work/tetex-src-3.0/libs/gd/gd.h
> /usr/ports/www/mod_php5/work/php-5.0.5/ext/gd/libgd/gd.h
> Then I did a:
> #./configure --with-gd=/usr/local/include
> But got the same error. Also got the error when I tried #./configure
> --with-gd=/usr/local/lib
> I think I'm not an experienced user with Unix, and this task is going
> to be harder for a non-unix user.
> But if anyone has something that could help... I'll be glad to hear
> about it! ;)
> Thanks to all.
> Cheers!
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> On Behalf Of Gavin Simpson
> Sent: Viernes, 11 de Noviembre de 2005 09:26 a.m.
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> On Fri, 2005-11-11 at 09:03 -0600, Alejandro Mejia Evertsz wrote:
>>I'm a newbie on this unix stuff, but I know a little bit about ports,
>>so I tried installing MapServer using ports, but it failed, so I
>>decided to install it manually.
>>When I do the ./configure I get this error:
>>configure: error: Could not find gd.h or libgd.a/libgd.so in
>>/usr/local. Make sure GD 2.0.16 or higher is compiled before calling
>>configure. You may also get this error if you didn't specify the
>>appropriate location for one of GD's dependencies (freetype, libpng,
>>libjpeg or libiconv).
>>But I know I have GD installed, and it's higher than the one
>>requiered:
>># pkg_info | grep gd
>>gd-2.0.33_3,1 A graphics library for fast creation of images
>>gdal-1.2.1_2 A translator library for raster geospatial data
>>formats
>>php5-gd-5.0.5_1 The gd shared extension for php
>>I don't know what to do next...
>>Can somebody help me?
>>Thanks in advance.
> If configure can't find gd itself then you need to help it out. try:
> whereis gd
> at in bash/shell for example, or search for gd.h, then specify the
> location in the configure line, --with-gd= etc. I don't know your
> system, but on linux you'd also have a gd-devel package that contains
> the headers (gd.h) that you need to compile against. So even though
> you have gd, you don't seem to have the devel headers installed, you can
just use gd.
> HTH
> G
> Gavin Simpson [T] +44 (0)20 7679 5522
> ENSIS Research Fellow [F] +44 (0)20 7679 7565
> ENSIS Ltd. & ECRC [E] gavin.simpsonATNOSPAMucl.ac.uk
> UCL Department of Geography [W] http://www.ucl.ac.uk/~ucfagls/cv/
> 26 Bedford Way [W] http://www.ucl.ac.uk/~ucfagls/
> London. WC1H 0AP.
