ECW on mapserver4.6
almudena rueda almudenarueda at INICIA.ES
Mon Nov 14 14:18:24 EST 2005
Hello Frank
I'm upgrading to mapserver 4.6 using the file
"mapserver-4.6.1-win32-php4.4.0.zip" from the MapTools site. I have upgrade
the dll's as well as the php version as said in the Readme file of that
distribution. I have notice that the gdal version now is 1.3 but the ECW is
the same as in mapserver 4.4, can the error be there?
Thanks
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Monday, November 14, 2005 3:16 PM
Subject: Re: [UMN_MAPSERVER-USERS] ECW on mapserver4.6
On 11/14/05, almudena rueda <almudenarueda at inicia.es> wrote:
> Hello all,
> I'm using php Mapserverscript and I'm trying to upgrade from Mapserver 4.4
> to Mapserver 4.6, everythng works well except the ecw files that makes a
> memory error when I try to show that kind of layers. I'm working in
Windows
> XP with Apache, and using phpMapscript dll. Does anyone know if I have to
> change anything on my .map file to use Mapscript 4.6, or what can I do to
> make the updgrade?
> Here is my ECW raster layer:
Almudena,
There is nothing apparently wrong with your LAYER definition.
When you upgraded to MapServer 4.6 where did you get your
ECW support?   I would encourage you to use the latest version
of the ECW SDK and GDAL 1.3.1.  If you downloaded binary
packages from somewhere, then please indicate where and we
might be able to reproduce the problem.  Otherwise there isn't
much that can be done to help.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
