ECW on mapserver4.6
Delfos, Jacob
jacob.delfos at MAUNSELL.COM
Mon Nov 14 18:58:15 EST 2005
Almudena,
I also had runtime memory errors with ecw, but only in php_mapscript
4.4.2. Maybe your php applications are still pointing to
php_mapscript_44.dll (if you kept it side-by-side). Make sure they load
the newer 4.6 version. The ecw runtime libraries (NCSEcw.dll, etc) are
the same ones as distributed with the 4.4.2 version. But they work fine
for me in version 4.6.1.
Regards,
Jacob
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of almudena rueda
> Sent: 15 November 2005 03:18
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] ECW on mapserver4.6
> Hello Frank
> I'm upgrading to mapserver 4.6 using the file
> "mapserver-4.6.1-win32-php4.4.0.zip" from the MapTools site.
> I have upgrade
> the dll's as well as the php version as said in the Readme
> file of that
> distribution. I have notice that the gdal version now is 1.3
> but the ECW is
> the same as in mapserver 4.4, can the error be there?
> Thanks
> ----- Original Message -----
> From: "Frank Warmerdam" <warmerdam at POBOX.COM>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Monday, November 14, 2005 3:16 PM
> On 11/14/05, almudena rueda <almudenarueda at inicia.es> wrote:
> > Hello all,
> > I'm using php Mapserverscript and I'm trying to upgrade
> from Mapserver 4.4
> > to Mapserver 4.6, everythng works well except the ecw files
> that makes a
> > memory error when I try to show that kind of layers. I'm working in
> Windows
> > XP with Apache, and using phpMapscript dll. Does anyone
> know if I have to
> > change anything on my .map file to use Mapscript 4.6, or
> what can I do to
> > make the updgrade?
> > Here is my ECW raster layer:
> Almudena,
> There is nothing apparently wrong with your LAYER definition.
> When you upgraded to MapServer 4.6 where did you get your
> ECW support? I would encourage you to use the latest version
> of the ECW SDK and GDAL 1.3.1. If you downloaded binary
> packages from somewhere, then please indicate where and we
> might be able to reproduce the problem. Otherwise there isn't
> much that can be done to help.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial
> Programmer for Rent
