mapscript crashes on getFeature
Lowell.Filak lfilak at MEDINACO.ORG
Tue Nov 15 13:09:15 EST 2005
Donovan writes:
> I've been working with mapscript and tomcat for several weeks, generally
> mapserver is working great but when i try to query a layer (tried a polygon
> shp file, polygon tab file and a point tab file) the jvm crashes as soon as
> getFeature is called.  QueryByPoint and getResults appear to work - i can
> iterate over the resultset and print shape indexes but getFeature always
> crashes with this message:
>> *** glibc detected *** free(): invalid pointer: 0x093f6e30 ***
>> 15/11/2005 10:48:04 11023 jsvc.exec error: Service did not exit cleanly
> Any ideas?  I'm really stuck...
> Following is a snip of the code and some more detail:
> layer.queryByPoint(map,point,mapscriptConstants.MS_MULTIPLE,-1);
> resultCacheObj results = layer.getResults();
> layer.open();
>     for (int i=0;i<results.getNumresults();i++) {
>         resultCacheMemberObj result = results.getResult(i);
>         shapeObj feature =
> layer.getFeature(result.getShapeindex(),result.getTileindex());
> f.realLayer.close();
> I'm using mapserver 4.8.0 but also tried 4.6.0 - same results
> I compiled mapserver myself with these flags
> --with-gdal --with-ogr --with-postgis --with-proj --with-threads --with-png
> --with-geos --with-gd --enable-debug
> gdal-1.2.6,  proj-4.4.9 and geos-2.1.1 were installed using RPMs from
> mappinghacks.com
> JDK 1.5.0_05
> Tomcat 5.0
> Fedora core 3
> I tried loading the jvm in GDB but it don't have the skill to track down the
> source of the memory corruption.
> Searched the list, google and the documentation with no success...
Donovan,
This isn't going to help a whole lot but I know this came up before but I
think the result is in the new archives and the search doesn't work.
Someone should remember posting that error before - if you don't receive
anything try submitting with the error as the subject line and that may
catch the needed eye.
Lowell
