dynamic layer filter, again
Stephen Davies
sdc at SDC.COM.AU
Wed Nov 16 02:03:01 EST 2005
I just today succeeded in getting layer filter changes via URL to work by
following the ideas in the CGI Reference. ie
...&map_layername_filter=sql_expression...
HTH,
Stephen
On Tue, 15 Nov 2005 16:52:04 -0300, Mauricio Stange H. <mstangeh at GMAIL.COM>
wrote:
>Hi, me again,
> please, does somebody know, how to do this. I already have posted
>the question.
> Since then I tried with every time recreating a mapfile, (reading
>from a map file without the filter and inserting it in the new file),
>but I have problems with it, sometimes I select another filter and the
>map does't change unless I use a map control.
> I tried with mapscript too: got the map, got the layer, and have set
>the filter property, but how update the modified layer into the map???
>Please, if somebody have an idea....
>Thanks,
> Mauricio Stange H.
