NetCDF in Mapserver...
Norman Barker
nbarker at RSINC.COM
Wed Nov 16 07:17:47 EST 2005
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Andrea Marelli
Sent: Wednesday, November 16, 2005 12:02 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] NetCDF in Mapserver...
Hi all,
I can't see anything (only a white image) when I try to use mapserver with
NetCDF files.
I need some suggestions...
The server has installed Mapservser 4.6.1 (with support for
Proj/Geos/Gdal/Postgis/Wfs/Wcs), Gdal 1.3.1 (support for
Postgres/Geos/Proj4/Netcd) and NetCDF 3.6.0-p1, ...
The NetCDF file's Header is:
netcdf N20001832000213_MO {
dimensions:
lon = 1480 ;
lat = 1207 ;
variables:
float lon(lon) ;
lon:units = "Degrees" ;
lon:long_name = "Longitude" ;
float lat(lat) ;
lat:units = "Degrees" ;
lat:long_name = "Latitude" ;
float chlor_a(lat, lon) ;
chlor_a:units = "mg.m-3" ;
chlor_a:long_name = "Chlorophyll a concentration, OC4v4 Algorith
m" ;
chlor_a:missing_value = -9999.f ;
float K_490(lat, lon) ;
K_490:units = "m-1" ;
K_490:long_name = "Diffuse attenuation coefficient at 490 nm" ;
K_490:missing_value = -9999.f ;
float nLw_412(lat, lon) ;
nLw_412:units = "mW.cm-2.sr-1.um-1" ;
nLw_412:long_name = "Normalized water-leaving radiance at 412 nm
nLw_412:missing_value = -9999.f ;
float nLw_443(lat, lon) ;
nLw_443:units = "mW.cm-2.sr-1.um-1" ;
nLw_443:long_name = "Normalized water-leaving radiance at 443 nm
nLw_443:missing_value = -9999.f ;
float nLw_490(lat, lon) ;
nLw_490:units = "mW.cm-2.sr-1.um-1" ;
nLw_490:long_name = "Normalized water-leaving radiance at 490 nm
nLw_490:missing_value = -9999.f ;
float nLw_510(lat, lon) ;
nLw_510:units = "mW.cm-2.sr-1.um-1" ;
nLw_510:long_name = "Normalized water-leaving radiance at 510 nm
nLw_510:missing_value = -9999.f ;
float nLw_555(lat, lon) ;
nLw_555:units = "mW.cm-2.sr-1.um-1" ;
nLw_555:long_name = "Normalized water-leaving radiance at 555 nm
nLw_555:missing_value = -9999.f ;
float nLw_670(lat, lon) ;
nLw_670:units = "mW.cm-2.sr-1.um-1" ;
nLw_670:long_name = "Normalized water-leaving radiance at 670 nm
nLw_670:missing_value = -9999.f ;
float l3m_data(lat, lon) ;
l3m_data:units = "Einstein m^-2 Day" ;
l3m_data:long_name = "Photosynthetically Available Radiation" ;
l3m_data:missing_value = -9999.f ;
float sst(lat, lon) ;
sst:units = "Degrees" ;
sst:long_name = "Temperature" ;
sst:missing_value = -9999.f ;
// global attributes:
:Year = 2000s ;
:Month = 7s ;
:Southernmost_Latitude = 22.f ;
:Easternmost_Latitude = -20.f ;
:Northernmost_Latitude = 75.f ;
:Westernmost_Latitude = 45.f ;
:Number_of_Columns = 1480s ;
:Number_of_Rows = 1207s ;
######### end of NetCDF file's Header ########
and this is the mapfile:
MAP
NAME "Test"
EXTENT 22 -20 75 45
SIZE 600 600
SHAPEPATH "/raid/emis/satellite_test"
LAYER
NAME "chlor_a"
TYPE raster
STATUS DEFAULT
PROCESSING "BANDS=3"
DATA "N20001832000213_MO.ncdf"
CLASS
NAME "chlor_a"
STYLE
COLOR 255 0 0
END
END
END
END
######### end of Map file ########
So, why I can't see anything?
Is there anything wrong?
Please Help me..
Thanks!!!
Andrea
Hi Andrea,
are you trying to serve netCDF using a WMS, or a WCS? If it is a WCS then there is a tutorial here http://ms.gis.umn.edu:8081/ms_plone/docs/howto/WCSServerFormatHowTo and I would be grateful for any feedback on how to improve this documentation.
Norman
