off topic - Simple Oracle spatial Viewer
Aniruddha S. Khadkikar as.khadkikar at NCL.RES.IN
Thu Nov 17 02:33:26 EST 2005
Hi Martin,
One way of looking at the data within your Oracle Spatial tables is by
using the spatial index advisor. I am assuming that you have already
created tables, added the metadata and built a spatial index on your
spatial table. Once you have done this, through Oracle Enterprise
Manager do the following:
1. Connect to the database
2. Now go on the upper menu to Tools and select spatial index advisor in
the database applications submenu
3. Add the layers from the relevant schema.
4. Using this you can see if the data has been properly populated or not
and do other things too.
Best wishes
Aniruddha
Martin Tomko wrote:
> Dear List,
> I am looking for some light & simple viewer for the data in Oracle
> Spatial, so that I can play figure out what is what beofre setting up
> projects and so on... I tried all kind of OSS (uDig, QGIS,...) all
> without luck. uDIG + Geoserver WFS would do it, but it seems to be a
> very heavyweight solution... I want something desktop based, no server
> side mapserver implementation or so... Please, let me know if there is
> anything available...
> Martin
ANIRUDDHA S. KHADKIKAR Ph.D.
Digital Information Resource Centre
National Chemical Laboratory
Dr. Homi Bhabha Road
Pune 411008, INDIA
Phone : 91 020 25893457 (Off)
Fax   : 91 020 25893973
Email : as.khadkikar at ncl.res.in
Web   :  http://www.ncbi.org.in
This email is virus free by TrendMicro Inter Scan Security Suite.
