Install shapelib HELP
Frank Warmerdam warmerdam at POBOX.COM
Thu Nov 17 10:37:35 EST 2005
On 11/17/05, K Kuo <mtrp36 at hotmail.com> wrote:
> 4. change directory to /usr/local/src/shapelib-1.2.10/contrib/tests and type
> make
> I got message as follow:
> make: *** No targets specified and no makefile found.  Stop.
K.
I suspect you want to do this ("make") in the contrib directory, not
contrib/tests.
> The book indicates there is a syntax error in the script shpproj.sh
> I edit the file and change dbfcreate test -s 30 fd to dbfcreate test -s fd
> 30 then save it and run make check
> Error message as:
> make: *** No rule to make target `check'.  Stop.
BTW, there is a shapelib mailing list, see http://shapelib.maptools.org
Best regards,
