A little help please
Gary Watry
watry at COAPS.FSU.EDU
Thu Nov 17 11:45:29 EST 2005
I tried both the Javascript and Html only solution. The javascript works
better and it does open a image of the site but when I click on any of the
buttons I get
The page cannot be found
The page you are looking for might have been removed, had its name changed,
or is temporarily unavailable.
Please try the following:
* Make sure that the Web site address displayed in the address bar of
your browser is spelled and formatted correctly.
* If you reached this page by clicking a link, contact the Web site
administrator to alert them that the link is incorrectly formatted.
* Click the Back button to try another link.
HTTP Error 404 - File or directory not found.
Internet Information Services (IIS)
I assume this is an IIS problem, any suggests?
On Mon, 7 Nov 2005 23:29:50 -0500, Richard Orth - osmoGIS Incorporated
<rco at OSMOGIS.COM> wrote:
>An initialization string must come from somewhere. It tells the service
>where to start, which map file to use, layers to start with, etc. For
>auto-starting your map service you have at least two options.
>1. A javascript redirector. just place the following code in its own file:
><pre>
><meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
><html>
><head>
><title>Welcome to ...</title>
><script type="text/javascript" language="JavaScript">
>function DoMe() {
>document.location = "/cgi-bin/mapserv.exe?" +
>"zoomsize=2&layer=tidestations&layer=countries&layer=states&map=c:\inetpub\wwwroot\mapdocs\tester.map";
></script>
></head>
><body onload="DoMe()">
><h1>One moment please...<br>Page Loading</h1>
></body>
></html>
></pre>
>2. An HTML only solution. Just change the width and height values to fit
>your service.
><html>
><head>
></head>
><iframe width=600 height=400
>src="/cgi-bin/mapserv.exe?zoomsize=2&layer=tidestations&layer=countries&layer=states&map=c:\inetpub\wwwroot\mapdocs\tester.map"></iframe>
></body>
></html>
></pre>
>Hope this helps
>Richard C Orth
>Gary Watry wrote:
>> Here is a development site I am working on,
>> I have borrows button icons from Canada, and most of the borrowed code
>> comes from the tutorials, or is noted in the source code.
>> http://indianocean.coaps.fsu.edu/httpdocs/tester.html
>> The two issues are sort of related.
>> 1. I would like to have just one page, so I dont have the
>> initialization page like I currently do. What is this done in and
>> where does the initialization code from tester.html go? Does it get
>> put into the tester1.html file?
>> 2. I want to put the little clip or animation that tells people to
>> wait while the program maps are loading. For example like on the
>> Canadian site
http://atlas.gc.ca/site/english/maps/environment/naturalhazards/majorforestfires
>> Any thoughts would be appreciated?
>> I am a GIS user/administrator getting into Open Source programming and
>> can use any help I can get
>> Thanks
>> ______________________________________________________________
>> Gary L. Watry
>> GIS Coordinator
>> Center for Ocean-Atmospheric Prediction Studies
>> FSU / COAPS
>> Johnson Building, RM 215
>> 2035 East Paul Dirac Drive
>> Tallahassee, Florida 32306-2840
>> E-Mail: watry at coaps.fsu.edu <mailto:watry at coaps.fsu.edu>
